18 inch rear wheel on VFR 750
12 posts Started 11 Mar 2012 Last recovered post 14 Mar 2012 Wayback Machine snapshot 10 Jul 2017
Hi All,
More questions for my RC30 replica project!
I have an RC30 18 inch rear wheel which I will be putting on my 4th gen VFR.
The original is 17 inch so in effect I will be raising the ride height by 1/2 an inch.
I'm putting in a CBR 929 rear shock and from what I've found out on this forum I need to add a 39mm spacer to match the existing setup.
Will the extra 1/2 inch (or 12mm) ride height affect the handling, should I shorten the spacer to 27mm to take account of this?
I'll probably play around with raising the rear/lowering the front later on but would like the original set up first to compare it with.
Can anyone help me out with this?
Cheers
Sean
You're gonna have trouble finding quality sport tires for an 18" rim.
The hot mod for an rc30 is to swap on a 17" rim and keep the 18 for a coffee table/conversation piece. That way, it "could" be returned to standard if desired.
seansparkleI'm putting in a CBR 929 rear shock and from what I've found out on this forum I need to add a 39mm spacer to match the existing setup.
It will increase (steepen) fork rake, which is a good thing - you'll get the same sort of improvement as dropping the triples down the forks by 10mm or so. The bike won't be quite as neutral (slow steering) but will turn in more readily and generally feel lighter and more responsive.
I'm with Rob, though - a 17" tyre will give you a far wider range of tyre choices.
To fit the 18" rim I assume you are looking at doing a Triumph hub conversion?
Veefer800Canuck
lol i have an hrc 18 rear from rs250 honda its now a clock
Are you aware that the RC30 rear wheel is a single nut and the VFR a 4 bolt/nut?
The Dunlop D207 for the V-Rod is a decent tire, not up to the best of today, but decent.
I have an RC30 if you need measurements or pictures.
SamW
Hi, Thanks for your reply, I have an NC30 swingarm, from what I have read the nc30 spindle will fit directly into the 4th gen swingarm so shouldn't be a problem.
I'm aware of the problems getting tyres to fit, but love the look of the original wheel, plus I;m doing an RC30 replica so trying to get as near as possible to the original look.
Thanks for the offer of photos, I will probably take you up on that!
SamW
Ughhhhh....Dunlop D207s??! They were like the worst tires I ever had on a bike! The handling on those get really spooky when they wear down a bit, especially as the fronts cup severely. I'd say, stay away from D207s if you can!
Beck
95 VFR
Beck
Beck
95 VFR
+1. Dunflop 207's are terrible. Don't last that long, awful cupping, take forever to warm up. The only time I lost control of my old R6 was on the 207's and I was only doing 10 mph making a left turn at a light when it turned green. Definitely go with another tire if you have a choice.
seansparkle
SamW
The eccentric will slide into the swingarm, however it is narrower by about 10mm if I remember correctly. I know VFROEM on here has done it, but I'm not sure how he made up the difference.
An RC30 eccentric is supposed to be a direct fit, you only need to modify the caliper mount/stay from what I've seen.
vanion2
Beck
Beck
95 VFR
Well, not many other options in a 180/55 -18 tire, mostly V-Rod intended non-sport tires. I used the 207's for my Class School at Barber, no real issues at all, I was not racing, but I was dragging, they did great. Most 170/60 - 18 tires are sport touring tires at best. Very limited choice of tires for an 18" wheel.
"Hi, Thanks for your reply, I have an NC30 swingarm, from what I have read the nc30 spindle will fit directly into the 4th gen swingarm so shouldn't be a problem."
OK, that makes sense. It should be an interesting build, good luck!
kostritzer
seansparkle
SamW
Thanks,
I've yet to try it, but will be starting a new thread with lots of photos when I have everything ready to go.
Ideally an RC30 swingarm would be the best option but as you can imagine they're as rare as rocking horse, er, teeth!
Sounds interesting. Ping Rick Oliver in the UK (you might find him on the RC30 Owners Club Yahoo group). He might be able to help you out directly.
End of thread · 12 posts recovered Wayback Machine snapshot 10 Jul 2017
