After having a heavy fuel leak, I pulled the carbs and found a cracked fuel line. Replaced it. Put carbs back on bike, rode well for a week.
Then it began leaking even more than before, I can see fuel shooting out of the fuel rail in more than one place. I don't think I stressed the fuel rail, I know it's fragile plastic. I do understand that the o-rings may have gone bad, but several at once? And with fuel not just dripping, but shooting sideways with the pressure from the fuel pump?
I have removed the carbs again and don't see any obvious damage.
It makes sense at this point to replace all the fuel rail o-rings, but I'd like to know: What regulates the fuel pump? What prevents it from pushing too much fuel with too much pressure? If a fuel pump is going bad, will it push too much fuel? As in, if my fuel pump was on the outs, would it blow fuel past the o-rings and cause it to shoot out of the carbs like this?
