#1 Thread starter
I have a 1999 VFR.
I recently installed a set of rider peg lowering blocks from Larry at BusyLittleShop (BLS). They are amazing.
I cut off about 1/4"(with a dremmel) from the threaded end of the rear master cylinder piston as recommended and lowered the pedal by rotating the piston.
Now the rear brakes drags badly. The pads eventually back off the rear disc if I let the bike stand. I have even disconnected the pedal in an effort to isolate and diagnose the problem. The rear brake drags even if I push the threaded piston up with my hand, it will not reset!
The front brake lever and front brakes work and reset fine (obviously operating the front brake lever does activate the one piston in the rear (Honda LBS) brake.
Cannot figure out the problem here. It is related to my installing the lowering blocks and adjusting the pedal for comfort. The problem persists even with the pedal in any position/disconnected.
I had no issue prior to installing the blocks and adjusting the pedal.
Any assistant would be of much help.
I am mystified!
Stephenm
I am mystified!
Stephenm
