http://i13.photobucket.com/albums/a280/veefer800canuck/footpegs/Picture001.jpg
Well, these little guys have been floating around on the top of my toolbox for quite awhile now, and this past weekend I made the effort to install them in preparation for the ride to Laguna and MotoGP Baby! :wheel:
I began on the shifter side, firstly removing the peg feeler (more on that later):
http://i13.photobucket.com/albums/a280/veefer800canuck/footpegs/Picture002.jpg
I had to do a bit of filing to get things to fit, but my peg hangers are powdercoated, and the coating is pretty thick as compared to paint, so that was probably most of the difference right there.
13 inches to the bottom of the footpeg with the lowering block, bike on centrestand:
http://i13.photobucket.com/albums/a280/veefer800canuck/footpegs/Picture005.jpg
And the stocker on the other side; 14.5 inches:
http://i13.photobucket.com/albums/a280/veefer800canuck/footpegs/Picture004.jpg
Here's the difference measured at the knees:
http://i13.photobucket.com/albums/a280/veefer800canuck/footpegs/Picture006.jpg
I then loosened the shift lever and lowered it down 2 notches on the splined shaft. It's one of those "test and try" things to see what's comfortable for you.
At first, I had only gone 1 notch, but the shifter was too high and I was constantly having to lift my foot up for downshifts. Much better now.
The next bit of trouble was the sidestand hitting the lowering block when retracted. I think someone else with the BLS blocks did this trick, so I stole the idea.
I drilled and tapped the sidestand for an M4x10mm bolt so the head would contact the sidestand stop bolted to the frame. There was a little too much clearance after that, so I strategically ground down the bolt head until the clearance was satisfactory, approx 3/8" or so:
http://i13.photobucket.com/albums/a280/veefer800canuck/footpegs/Picture007.jpg
http://i13.photobucket.com/albums/a280/veefer800canuck/footpegs/Picture008.jpg
http://i13.photobucket.com/albums/a280/veefer800canuck/footpegs/Picture009.jpg
Lastly, I removed the sidestand tang as it was lightly contacting the bottom of my foot on upshifts.
The brake side was mostly Lather, Rinse, Repeat:
http://i13.photobucket.com/albums/a280/veefer800canuck/footpegs/Picture010.jpg
You can also see that in place of the footpeg feelers, I substituted an M8 allen head bolt which I shortened so it would screw all the way in and tighten against the footpeg.
However, in order to get the brake lever down as low as possible, I had to eliminate the locknut from the brake rod (red circle) and shorten the threaded brake rod (arrow). I used a drop of locktite to keep the lever bracket from moving and as far as shortening the threaded rod, well, when I did the RC51 fork mod, I had custom fit a CBR600F4i rear master cylinder and I had left the brake rod longer than stock "just in case". In case of what, I'm not sure, but that was probably the reason it needed to be shortened in my situation:
http://i13.photobucket.com/albums/a280/veefer800canuck/footpegs/gallery_554_564_625346.jpg
As well, the brake light switch did not have enough adjustment and the brake light was naturally on all the time, so I had to remove the switch actuating spring and stretch 2 or 3 coils, effectively making the spring longer and allowing for the light switch to perform.
One thing I have not yet done is to remove and stretch a couple of coils on the lever return spring. The brake pedal seems a tad stiff with the spring pulled more taut, owing to the lower position of the lever. Brake engagement/disengagement is fine though, I tested that by spinning the wheel on the centerstand with the bike off in neutral and also with the bike running in gear.
Final verdict: if you have knees older then 40 years and/or do a lot of LD riding, then these are the things for you. :thumbsup: :thumbsup:
Great product, Larry puts on a good show. There is tinkering involved, and Yes Virginia, you do lose a bit of cornering clearance, but as long as you don't ride like Rickey Racer, you'll be fine.
Oh, and keep those toes up on the pegs!
Nice pictures....thanks for posting it up for us.
Breaking
Rule 5, tsk tsk.
Nice photo essay on this mod, very interesting to see how they install!
[image: View Post]elizilla, on Jul 8 2007, 12:14 AM, said:
Breaking
Rule 5, tsk tsk.
Heh, well, I tested them out before departure and all is well.
Just gotta remember to keep my toes up on the pegs in the twisties!
Just a bump to say how awesome these peg blocks were on the trip to Cali and back.
I was snug as a bug in a rug.
I used to have hip joint pain on long rides, some cramping, etc, but not with these babies.
I drug pegs exactly twice on the trip, once on each side. Sidestand did NOT drag ever.
I'm leaving them on full-time, I see no need to remove them when not touring.
:thumbsup: to Crazy Larry and his lowering blocks.
Ricky Racer? I think you have to be over 50 to know this term. Great post and a good looking product for my forty something puck less knees. :goofy:
Any one willing to give out dimensions on these blocks? I'm looking to make them myself, having some measurements will make it easier.
Sorry, I know this is an old thread.....
Are these foot pegs available in Canada? Where did you buy them? Or did you make these yourself? I'm very interested.
Thanks.
J
send a pm to member busylittleshop. he is on this board regularly and makes these. great product, great delivery and yes he will ship to canada
Awesome!!!
Thanks for the info! :beer:
J
Hey,
What did you use to remove the sidestand "tang?" Would a dremel work?
Also, how did you remove the locknut from the brake rod, and is it necessary to shorten the brake rod if I have the stock master cylinder installed? In your opinion, would it be necessary to mess with (stretch) the brake light and brake lever springs if I eliminate the locknut and set the lever a bit lower to accomodate the lowering pegs?
Hey,
Probably, but an angle grinder with a ZipCut disc is so much more effective, followed by a trip against the bench grinder and some spray paint.
You need to remove the pin (gold thing in the pic) and thread the upside down "U" shaped swivel connector to take the locknut off.
Not sure of it would be required with the stock rear master cylinder or not. As I mentioned in my post, I had an F4i rear master due to my brake delinking, and the pushrod was WAY longer than the VFR one. I shortened it, but left it a tad long "just in case". Can always go shorter, but mighty tough to lengthen!
So, you MIGHT get away with just removing the locknut, if you run out of adjustment on the black swivel piece (meaning the threaded rod contacts the bottom of the upside-down "U" shaped swivel piece) than you might have to shorten the pushrod.
You might have enough adjustment on the barrel of the brake light switch, you can thread the plastic adjuster wheel to make/break where the light comes on when you depress the pedal, so by doing that, maybe you can get the brake light to work.
You'll have to look at it all once it's installed and figure out from there which way you need to go.
Hey,
Thanks for responding so quickly! Don't have an angle grinder, so I'll see what I can use to cut the tang off.
$29.99 at Pimps 'n Queers:
http://www.sears.com...d=angle grinderThat's how I get tools. Just buy 'em when you need 'em and sometime later on, they're always right at hand!
My dad had a machinist friend from work make something similar for his (now mine) Gen5 back when he had it in '98-02. the milled aluminum piece went straight down at the same forward angle as the peg bracket naturally is cut out at. This set you have seems to be even further forward with that offset built in. With his he never had any issue with the kickstand hitting although it was too hard to deploy in my opinion. The other issue he had was that the shifter was now too close to the peg so he ended up cutting/shortening it and splinting it which made it a little shorter throw but not quite so close to the peg. It wasn't an issue to move it down -it was just too long still. The brake side he just heated up with a torch and bent to fit.
When I bought the bike I was touching down all the time in slow parking-lot manuevers. The VFR turns like a fat pig at slow speed because of the lack of steering lock and you really need a lot of lean angle (and often counter-leaning with your body) to get it lean over enough to U-turn like other bikes with decent steering lock. This would cause the pegs to really drag in the parking lot so after a couple of weeks I just took them out.
I still would drag the pegs with the stock set-up though until I swapped the rubber-topped pegs to the all-aluminum ones from a Gen1. I kept the shorter peg feelers of the Gen1 on there so now they hardly ever touch down. I don't have that rubber bumper on the C-stand so it doesn't touch down either.
I think with regards to touching down the pegs or other semi-hard stuff (stands) it's all about how you ride. I'm not a "fast rider" on the public roads but I do tend to lean a lot to get the bike to turn at slow speeds. I also ride mostly on slow-speed tight town back roads where a marked 15 or 20MPH turn will have you rubbing pegs at anything over 55-60MPH. I get my yayas off on roads like that. Doing 100-120+ sweepers on county roads just isn't good for your personal health or your license IMHO.
Yeah, that's a good idea. I didn't know they could be had that cheap. I don't have a bench grinder, so I may have to get one of those too.
How much are the blocks selling for?
They be $90 shipped. And I must say that BLS is a cool dude. I bought a set a couple of months ago, but returned them when it looked like I was going to have to modify my bike more than I wanted to in order to accomodate my long ass legs (e.g., lower shifter, lower rear brake, modify kickstand, and possibly trim fairings so my shins don't hit). BLS was very cool about taking the product back and refunding my money. Then, a couple of weeks ago, after getting my fill of discomfort while riding, I PM'd him to see if he'd be gracious enough to sell me another pair, and he did. Just wanted to get this out there.
$29 at K-mart? I don't shop at K-mart. I quit buying Craftsman once K-mart bought them out. For K-mart quality one might as well pay Harbor Freight prices. Their
angle grinder is regularly under $19, and I've seen it on sale for $9.99. It's pretty much indestructible. I think HF and K-mart pretty much have their stuff made at the same factories in China. I avoid the middleman and buy straight from China.inc/HF.
Electric tools are OK but the real power is in using pneumatic tools. If you have a decent air compressor I'm a big fan of the low-cost HF China-Pneumatic line of air tools. The air
angle grinder is pretty slick. Much better than an electric grinder other than you are tied to the air line rather than an electrical cord.
With the China-Pneumatic tools you just have to have a few extra O-rings on hand as they don't last as long before the first rebuild compared to the 10x the $ version like real Chicago-Pneumatic or Ingersoll-Rand. But if you clean up the rough spots inside while you are rebuilding with new O-rings they'll last nearly as long between rebuilds as their high-$ cousins. Air tools are dead simple devices IMHO.
I just installed a set on my '98 & am having some of the same issues with them as other members have had. At the point, it's abit disappointing.
First though, there is a right & left side with these blocks & they will only install one way, correct?
One issue I'm facing is the kick stand hitting the block. I'm considering checking with a local welder to find out if a bead of weld(is there is such a thing?) or some object can be welded to the kick stand to prevent this unwanted contact. Does anyone here have welding expience to know if this is possible? If so, does it seem to be a good solution? I'm thinking that if the object is too thick, I could grind/file it down till I'm satisfied with the kick stands position when up.
Also, can anyone tell me if the stand is difficult to remove/install on a '98?
And the brake pedal is another issue. What needs to be done to remove the nut to provide more adjustment?
TIA.
Not that this helps any of you guys that are having problems, but I had no issues with these whatsoever on my 6th gen. Just bolt in, adjust shifter and brake pedals, adjust brake sensor, and that's it. Must be a 5th gen only thing.
Mike
OK Chuck, here is a little more info on the sidestand mod, and how I accomplished it. The brake pedal mod is covered in detail in my 1st post, basically involves shortening the brake rod and removing the jam nut to make more room to adjust the brake pedal downwards.
As always, you must ensure your own safety and be certain that your brake performance is reliable and functioning 100%. [/disclaimer]
Hope that helps.
As always, Rob, very informative, great pics, and well written. I give it 4.5 William and Kate's out of 5!
Thanks Veefer but I DID understand that much from your first very well written & illustrated post. Doing it that way is beyond my capabilities though. And I think it would be easier & cheaper to pay someone to put a bead of weld or weld something in that same area to accomplish the same thing your bolt does.
One thing I am able to do is simply put a thick layer of electrical tape on the stand where it contacts the peg block which I'm considering doing at this point. That way,at least, it won't be metal to metal & they won't mar each other up.
With the brake pedal, I believe I understand how to take it apart to remove one of the nuts on the rod. But I can't quite picture how that will provide more adjustment for the pedal to be lowered though. It seems to me it would have the opposite effect. But I'm rather simple minded these days. It's probably one of those things which once I have it apart it will make perfect sense.
Can you confirm for me though that these blocks are NOT identical to each other? In other words, one will only fit on the right side & the other will only fit on the left side.
Yes I agree... I'm always impressed with Rob's level of help and if he ever returns to Laguna Seca I owe him dinner at Bubba Gumps and a test hop on you know who...
CHUCK2
[/color][/size]
Yeah, a weld bead would probably work, then fine tune it by grinding down.
If you look at the brake rod, the jam nut prevents you from turning the turnbuckle up all the way, efectively lowering the brake pedal on the other side of the pivot point. Also the brake rod is probably too long, and it will hit the turnbuckle, not allowing full adjustment, which is why I shortened mine. And I locktited the turnbuckle so the brake rod would not rotate during use and effect adjustment of the brake.
And yes, the blocks are mirror images of each other, so one is L and the other R.
I finished adjusting the brake pedal & would like to share some things I found to be interesting.
The black lever bracket is threaded. I sure would have liked to have known that to begin with. Then I could have understood how this adjustment works. It did not create any problem & became obvious right away. Perhaps this would be common knowledge to most but I don't do this sort of thing everyday. I realize now if that bracket was not threaded it would have required a nut to be below it. The 2 nuts were easily visible on my bike. But in the pic above, the top nut is mostly hidden by the black rubber boot. I see it now but I did not before. I was confused. I was thinking the adjustment was made by only these 2 nuts some how & how could removing one make any difference. But now that I know the bracket is threaded, it makes perfect sense as I had mentioned it probably would once I got working on it.
I'm glad the threaded rod spins freely as long as the top nut is tightly treaded as far as it can be toward the master cylinder(which mine was not since I had loosened it when trying to make this adjustment originally) & can be moved around. This made removing that bracket & nut easy. Veefer, was the reason you used lock-tite because that threaded rod can spin? I made the adjustment as far as I could without cutting the rod. I end up having to lift my foot alittle bit off the peg for it to be on top of the pedal but it is less than before the adjustment. And no big deal to me.
I'm also glad that brake fluid does not leak when that rubber boot is removed. That would have rotted my socks big time.
Once that is all reassembled, adjusting the brake light switch was easy. I still have space for more adjustment without having to do anything to the spring.
Another interesting thing to me is, in the pics above, it appears that the foot pegs are positioned closer to the shift lever & brake pedal after the installation of the lowering blocks. Mine are located further away which I think I prefer. I'll be trying to post some pics I took soon.
I did a similar mod to Veefer's:
[image: band.jpg]
I don't think you need to weld though if you can't drill and tap the sidestand. Get a small hose clamp at the local hardware store and insert a small spacer, metal, wood, whatever and secure it with the hose clamp. Adjust the size of the spacer so the sidestand is spaced where you want it. I did end up cutting off the peg that projects perpendicular to give my toes more room.
Thanks vfrcapn for the idea. I do have hose clamps of various sizes but I wouldn't like the way that would look. For now, I tightly wrapped a thick layer of electrical tape around the stand where it hits the lowering block. Being black on black, it's hardly noticable & creates a nice soft sound when contact is made. Instead of the bang of metal to metal. Time will tell how well it lasts.
I do like how your mod is done & looks. That will last forever & is easily adjustable. If I had the means & ability I might do that myself. But for now, I like my simple way.
How do you put the stand down without the peg that you cut off?
Thanks again. I do appreciate your input.
CHUCK2
Same concept with the electrical tape, it should last awhile but tape is cheap and easy to replace. I never used the peg to put the sidestand down, I just use the foot of the peg.
CHUCK2
Yes. I wanted everything to stay put and not rotate, therefore changing the pedal height or brake engagement point. Has worked 100% so far.
Veefer, are your pegs now located some what forward from their factory location as it looks in your pics? What year is that part of your bike?
so i went to install the BLS footpegs and the left side was no problem but can't say the same of the right. Basically best i can tell is that in order to get the brake pedal down far enough to be comfy w the peg lowered, one must indeed shorten the threaded brake rod as veefer800canuk says. but (see below - he evidently used a rod assy from another model) on my '02, the basic problem is that in order to shorten the rod enough to put the brake lever down to a comfy position, one must remove so many threads that, were one to remove the lowering blocks to take the pegs back up for sport riding, one would not have enough threads left - the clip that links the lever to the rod only allows for about oooh 3/8" of play total. So has anyone found a way around this conundrum, like perhaps a clip that allows more play ... anything that would allow one to actually go back and forth between having the lowering kit and not, with say under an hour of labor? I was thinking maybe I'd just get a second brake assy to swap out...any ideas greatly appreciated
Old thread or not, I just wanted to thank you Veefer for this thread. I just got my blocks in the mail and put them on. Wow! What a HUGE difference. I need to lower my brake lever and this is the thread that came up. Thanks again.
Wow, has it been 6 years???
I haven't taken the BLS blocks off, Still running them, still working great.
Pay careful attention to the footpeg feeler mod I did, it's perfect. I would recommend the same.
Veefer800Canuck
Its hard to believe but Peg Blocks, an exclusive VFRD product; is
entering its 6 year of keeping those knees in the breeze... I want to
thank Rob for his ingenuity and support that he tirelessly gives to
the membership and there's a table at Bubba Gumps reserved in your
name Rob anytime you return to Laguna Seca...
Best Mod Ever!
Has kept me on a VFR when 40 years of basketball tried to force my 6'2" frame onto another ride. I now can walk into work on Monday without a limp.
KEB
Just a quick thanks for this info.
I bought a set of lowering blocks for my 2000 VFR800.
I have yet to ride the bike with the lowering blocks installed but static testing tells me I'll be very happy with this mod.
TINK
You're welcome.
Be sure your pedals are properly adjusted and the rear brake is not dragging, and the brake light works correctly.
Other than that, your hips will thank you.
As will your knees. Great mod. I switched bikes earlier this year with another member on a ride and felt folded up like I was stuffed in a fridge. I wouldn't run a VFR without 'em.
The brake light thing can a bit tricky (at least on a 6th gen). I finally got a very small keychain split-ring at a hardware store and threaded it through the hole in the brake pedal and then through the end of the spring that goes to the switch. That gave it just enough extra length to keep the brake light from being on constantly.
Just a friendly reminder that PEG BLOCKS, a VFRD exclusive product;
are still available to keep your knees in the breeze... the price + USPS
flat rate priority shipping are as follows... as soon as I receive Pay
Pal payment the shipping starts... my account: netters2@comcast.net
USA Peg Blocks $85.00 + Priority Shipping $8.30 = $93.30
Canada Peg Blocks $85.00 + Priority Shipping $27.90= $112.90
Europe Peg Blocks $85.00 + Priority Shipping $38.60 = $123.60
Australia or Denmark $85.00 + Priority Shipping $39.60 = $124.60
What you see is what you get..
[image: gallery_3131_51_90651.jpg]
Rob's INSTALLATION GUIDE
http://www.vfrdiscussion.com/forum/index.php/topic/34097-bls-footpeg-block-install/
VFRD site support
http://www.vfrdiscussion.com/forum/index.php/topic/77384-peg-lowering-blocks/
[image: 1stIntructionSheet.jpg]
Can you reverse these and raise the pegs ?
SwitchbladeCan you reverse these and raise the pegs ?
You can but you will not like it...
THANK YOU BLS! Got mine, I just need to finish installing bags so I can go for a ride!
northwoodTHANK YOU BLS! Got mine, I just need to finish installing bags so I can go for a ride!
You're welcome... I'd like to thank Miguel for a great site and Rob for his great installation guide...
Finally got these installed after ordering them a couple of months ago and having them sitting on my shelf. Did the usual stuff:
- adjusted the shifter down a notch or two
- extended the brake light spring by using a split key ring (as suggested by many here)
- rotated the adjustment rod as far as it goes to get the brake pedal adjusted as low as it goes
I've seen people post about getting the brake pedal lower by backing the adjustment rod all the way out and cutting off a few threads with a Dremel. I'm having trouble figuring how to get the pin & nut off, there's no room back there to get any leverage at all. Can you guys provide a little more detailed guidance around how to get that rod out to cut off some threads?
Thanks guys!
I followed the procedure in my 03 VFR last night and did not have to cut the threaded brake rod at all but it’s at the max adjustment length. Did have to stretch, reassemble, restretch, and test the brake light switch and spring. Great info and thanks to an old thread!
This thread has become very valuable as I just installed a used set of these blocks on my 01. I am going to put 6th gen pegs on it for more space for the kickstand and modify the kickstand to accomodate as seen here. I maxed out the rear brake adjustment and think it will be alright as it is barely used. Thanks!
[image: IMG_1595.JPG]
[image: IMG_1596.JPG]
I have finished the kickstand modifications, as others have. Cut off the little foot and JB Weld-ed a small washer to keep the kickstand from going higher. Also installed 6th gen pegs becuase they are thinner. Right now I have just about 1 finger gap worth of space and it feels and looks good. 2 coats of Rustoleum satin black for finish. Can't wait to see how she rides!
[image: IMG_1623.JPG]
[image: IMG_1624.JPG]
[image: IMG_1625.JPG]
[image: IMG_1626.JPG]
[image: IMG_1627.JPG]
