Is there any other tank that will fit on our bikes or any other year that will work on the 5th gen
5th gen tank info
4 posts Started 3 May 2012 Last recovered post 3 May 2012 Wayback Machine snapshot 24 May 2012
I think 6th gen tank will work for the most part.
Yep, you can persuade a 6th gen tank to fit, will need to trim the edges of the upper fairings a tad as they interfere with the 6th gen tank.
Also, the rear flange of the tank needs to be drilled to fit the 5th gen hinge.
Front two bolts line up perfectly.
You can use the 5th gen fuel pump and sending unit, plus fuel cap in the 6th gen tank no problems.
Here's my bike with a 6th gen tank mounted (slightly disassembled for winter wrenching session):
sweet thank you 6th gen tank is cheaper then the 5th gens that i have been looking at
End of thread · 4 posts recovered Wayback Machine snapshot 24 May 2012
