I've been enjoying my 2000 VFR800 immensely since I got it this past winter.....put a couple thousand miles on it already due to the warm winter and unusually warm spring. Overall the bike runs great, gets great gas mileage (average 47mpg), and is a blast to ride.
That said, I noticed from day one some vibration that I never had with my old gen2 VFR700.....I know that bike was a completely different beast, but it was smooth as silk and this new bike feels like a log wagon in comparison sometimes. Here are the "symptoms"....
For starters, the bike runs/idles smoothly and pulls strong, however, when accelerating I feel a lumpiness or "chatter" vibration....almost what you would feel if the bike was in too high of a gear while trying to accelerate, but not that extreme. I feel the vibration in the bars and in the footpegs the most.
The other time that it gets noticeable is when cruising (in any gear really) between 4500 and 5000 RPM. The vibration almost feels like an out of balance wheel....but it definitely is not that....I can pull the clutch and coast at speed and the chassis is smooth as silk.....the vibration is definitely the engine/tranny. This is unfortunate, because cruising at about 65-70 mph is right in that range.
The bike has roughly 16k miles on it. It is due for the valve clearances checked right about now. Other than an oil change and filter replacements, i've not touched the drivetrain since getting the bike this winter. The chain and sprockets seem fine and the chain slack seems within spec.
This is my first Fuel Injected bike, so I'm unfamiliar with how these bikes normally run. Is it possible that this is a starter valve synchronization issue? Any other thoughts?
