I live in Athens / Greece. Having clocked approximately 150,000 km all over Europe on my trusty old CBF600S, I replaced it (last summer) with a dark-red VFR 800 VTEC ABS (RC46C / 2006). I bought it second-hand from a friend, with 17000km on the odometer. I ride all year long (the weather here is quite nice, even during most of the winter). I use the bike for commuting and touring. Most of the times I ride without a passenger (though not exclusively) and at quite a spirited pace. Sometimes (during longer trips) I use Givi Side-cases, but more often than not a small tail-pack and and a tank-bag are enough. I mostly ride on twisty back-roads which are not always perfectly paved (bumpy, cracked, rippled, slippery, etc). I plan to keep the VFR for long, so I think a suspension upgrade would be a good investment (paying back in riding pleasure, as well as increased safety).
For the rear suspension, the upgrade is rather straightforward (though quite expensive :tongue: ). I will replace the stock shock with an Ohlins HO605 (with external reservoir, hydraulic preload, and compression / rebound damping adjustment).
At the front, things are a bit more complicated. I lean towards installing stiffer springs and RaceTech's Gold Valve kits (for compression and rebound). Another option would be a complete axxion cartridge replacement kit, though I think I will not like the price, when I hear it. Finally, if all else fails, I will simply replace the springs with stiffer ones and maybe put a different grade oil (postponing other improvements for a later time).
After this rather long introduction, here are some questions for you:
1. Spring rates: I weight approximately 100kg (220 lbs). I think I will need 0.95kg/mm fork springs and a 19.3kg/mm shock spring. Or should I go for 1.0kg/mm fork springs and a 20.3kg/mm shock spring? Or something else? Keep in mind that the roads I ride are sometimes quite bumpy, so a very stiff setup might not be the best for traction (or am I wrong?).
2. Do you know if Ohlins or WP make fork-springs at these rates suitable for the VFR? (We have well-stocked local Ohlins and WP distributors here, so I could get them without having to wait to much for overseas delivery). If not, does anyone know where I could find springs at these rates for the VFR, in Europe?
3. If I change ONLY the fork springs and oil at the front (no revalving), what grade oil would you recommend? Would that be a TERRIBLE compromise? It's not so much a matter of cost (as I am prepared to pay for RaceTech's gold valves); it's mostly a matter of shipping delays, as I plan a long trip, in a moth or so, and I don't know if this is enough time to have them shipped over here.
4. What static / dynamic sag numbers should I aim for?
5. Any other suggestion you might have would be welcome.
(I posted a similar question here. Sorry for double-posting! Also, sorry if my English is not that good; I hope you can understand this post)
Thanks in advance for your answers, and keep riding!
:tour:
