750 rearsets?
9 posts Started 31 May 2012 Last recovered post 2 Jun 2012 Wayback Machine snapshot 4 Jun 2012
Hi All
Looking to track my vfr. Who sells rears sets for improved clearence?
Steve
[image: View Post]StevenBlanc, on 31 May 2012 - 09:03 AM, said:
Hi All
Steve
I have been told that 99 and older Honda 900 RR brackets will fit VFR's then you may have more pedal options, that is if your referring to the main pedals and brackets and not the passenger pedals.
I have a brand new set meant for a 900RR on my 750 track bike project.  PM me if you're interested.
Look on ebay for CBR900RR rearsets. Only downside is, you'll need to add a few spacers if you want to retain the standard shift pattern. I have a set (ebay chinese set) and they didn't break after installing and jumping on them. I'm no lightweight either...
bolt pattern is the same spacing on those? ?
where would you add the spacers? Where the shifter is attached?
I'll be installing a set too
Great stuff, pm sent, thank you for the replys
You'll see when you bolt them up. On the shifter side, the rearset may contact the swingarm, so you add a few washers to give it clearance. I don't remember now what exactly I did w/ the linkage, I know I have to shorten the rod.
End of thread · 9 posts recovered Wayback Machine snapshot 4 Jun 2012
