marriedman
Since I was feeling pretty confident after doing my recent bouts of maintenance, I decided to read the Service Manual and see how bad changing the clutch and brake fluid would be. Well, after reading 15 pages of just the brake bleeding instructions, I have decided it is too involved for one of my limited skills.
How bad would a dealer screw me over? Monetarily that is.
Hmmm. Your profile indicates that you have a 4th gen. that should be considerably easier to bleed than more recent issues (which have front and rear brakes connected). Here's a couple of thoughts for you.
1) Don't bleed them!
"Say what?"
Bleeding is how you get air out of the hydraulics. Air gets introduced only if a) you have drained the system entirely (perhaps to clean it), or b) you screwed up and sucked air while replacing brake fluid. In other words, there's no need to have air to bleed air, in the first place. (The shop manual takes you through the process from empty to full. You don't have to worry about that, since your system is full to start with).
Instead, chase the old fluid out with new fluid. This is *much* easier. Which brings me to...
2) Install something called Speedbleeders in place of the the brake bleeding ports. Speedbleeders are one-way valves (check valves) that allow fluid out, but prevent air from being sucked in. They'll cost you a few bucks, but probably a lot less than your mechanic will pound you for, and well worth every penny.
3) Not a necessity with Speedbleeders installed, but having a hand-held vacuum pump makes the process easier. Many of us use Mityvac's offerings, which serves the purpose well for not a lot of money.
4) Get a second person to top off the master master cylinders periodically, while you suck the old fluid out at the calipers. They can also work the brake levers to run fluid though the system, and out the bleed ports.
If you have no context for this yet, don't worry. it's really not all that hard. Read any internet description of brake bleeding, and you'll quickly get the idea. It's scary the first time, but soon just another task to get done.
Finally, and this happens to all of us (c'mon, admit it guys), sometimes you do get an air bubble. Learned a nifty trick once that works wonders. Compress the brake overnight (for example, by tightening the brake lever with a tie wrap around the right grip. A little more ingenuity is required for the rear brake). In the morning, release the brake lever. Bleed out a bit of brake fluid. Top off reservoir. Check brakes. Ride.
Seriously, first time jitters(and they are reasonable!) will pass. If you are at all mechanically inclined, go for it.
Good luck,
Aram
