I had the misfortune to have a spark plug blow out of the head recently. Apparently either I damaged the threads installing the last set of spark plugs, or someone in the bike's previous life (which has been long and sorted) did. Either way I need to either drop the motor and replace the head or buy a timesert kit. I have ruled out helicoils after reading too many negative comments about using them for spark plug repair.
10mm x 1.0 is the thread I think, correct me if I am wrong. But how long of inserts do I need? The kit comes with 15mm, but there appear to be shorter ones available.
Thanks in advance for your help!
