VFR 1200FD Brake mod
1 posts Started 15 Aug 2012 Last recovered post 15 Aug 2012 Wayback Machine snapshot 30 Mar 2020
I'm trying to upgrade the stock brake system on my 1200, but I'm not sure if it would interfare with the ABS system. I'm looking at a few things for it so far:
Brembo master cylinder [ http://www.oppracing...ster-cylinders/ ] that website is not that good since it dosnt list a master cylinder for the 1200 or a way to figure out what size could you use, this one does through explain "how to" [ http://www.cyclebrakes.com/html/brembo_cylinders.html ]
that one is one of the parts Im not so sure would fit right due to the ABS, any one swapped theirs? Thinking about getting one for the rear later on as well.
Stainless steel brake lines front and back [ http://www.galferusa...ng-motorcycles/ ]
I'll need the stock dimensions to get those made, if theyre not in the manual than it will be a little bit of searching around and measuring with a string to do...
Brake pads EBC Sintered Double-H Rated Pads front and back [ http://www.perfectbr...ts.asp?cat=4083 ]
Since calipers from Brembo are like 2000$ for just the front set and rotors are around 600$ a pop I decided to stick to stock with those...
Do any of you know where is the ABS chip connected, and would swapping the master cyliner impact it in any way?
Edited August 15, 2012 by Devorlast
End of thread · 1 posts recovered Wayback Machine snapshot 30 Mar 2020
