After talking to the guy at the inspection station, we decided a place to start would be testing the ignition system and checking for vacuum leaks.
I performed the entire ignition inspection procedure per the manual and found that everything was good but the ignition pulse generator.
What I read at the CDI box plug was 320 ohms and I am supposed to read 450-550 ohms.
At the pulse generator plug I am supposed to read 200 to 400 ohms, but I am getting 3.4 mega ohms and on the second check its reading as open.
How would this effect how the bike runs?
Plus while it was running I sprayed some starting fluid around the carb base and the bike started to rev up.
Upon taking the carbs off the boots were very hard and had some cracks in them. Plus while I have them out I plan to use a depth mic to bench sync them.
