At 5000 rpm, keeping constant throttle and running below 100 kph, the bike seems to run jerky.
It acts as if I would slightly open the throttle and shortly after that it acts as if I would keep it steady at 5000 rpm. (it sort of swings you back and forth as it cycles this behavior)
This translates in a rough but noticeable running and it is very noticeable in the first 3 gears. Experiencing this on smooth pavement surface, so the bumps aren't doing this.
It hadn't had this problem since I took it in service last week for a stator and Regulator Rectifier replace and a check of the charghing system (roughly 14v on the battery with the bike started and at idle).
The rectifier looks a bit not-stock, I will look into if it is what I need on my bike.
But I doubt this would be the issue. I tried checking the chain for uneven wear and tight spots but it feels the same throughout its length.
One other thing I am doing now is checking if the gas the bike has might be of poor quality so I am going to burn this one and change the gas station company.
