Hey guy's does anyone know if the levers are the same on the Sixth and Seventh Gens? I know that the Throttlemeister throttle lock is the same, but I can't seem to find any info on the levers. I'm looking for some Pazzo's but can't find them.
Thanks.
Why, do you need stock levers for the 1200?
I have a set that will never see my motorcycle again because Pazzo shorties look and feel a ton better and you can have them cheap.
Why, do you need stock levers for the 1200? I have a set that will never see my motorcycle again because Pazzo shorties look and feel a ton better and you can have them cheap.
With your Pazzo's installed does your brake switch still work on the front lever?
