08 with LV carbon slip-on using PCV?
5 posts Started 14 Sep 2012 Last recovered post 15 Sep 2012 Wayback Machine snapshot 26 Sep 2012
as titled, need to know which map to use for my specs  PLEASE.
Go here http://tinyurl.com/9kswtfk and download the 126-004 map or the 126-all file, otherwise you can go to the download section of the VFRD forum and see what others have posted up. There are quite a few custom maps to choose from. You'll have to read the descriptions to see what their setup is.
thanks, loaded the map.
anyone refined it yet?
Check in the downloads under coderighter, I've got a map up there that should work for you.
loaded
06 PCV Autotune generated map Rev 15
. my pair still active
more ridable in low gear /low RPM
vtec transition not as seamless as dynojet map at times but much smoother than stock
5k flat gone
pulls very well above vtec
temp rises alarming 20F-30F in minutes when riding hard(lean?)  smelled very hot after a hard 20 minute
End of thread · 5 posts recovered Wayback Machine snapshot 26 Sep 2012
