Stem valve failure
10 posts Started 27 Sep 2012 Last recovered post 27 Sep 2012 Wayback Machine snapshot 1 Nov 2013
Riding back to Atlanta at 90 MPH on GA 400 I suffered an instantaneous loss of air pressure in my front tire due to the failure of my stem valve. This became apparent when I couldn't turn the front wheel. After gradually slowing down ( no brakes) and very gradually angling to the side of the highway I pulled off into the grass at about 20 MPH (too fast) and almost lost the front end during violent head shaking.
The bike is in my garage and I have one observation and one question.
1.In the future I will carry a Canyon Dancer (or similar) harness under my seat. I was on the side of the road for four hours trying to get towed because my free AMA towing connection couldn't find a single tow company who could strap down a sport bike without damaging the front fairings. I ended up calling a motorcycle tow company from Atlanta to come get me.
2. The tire looks perfect. Would anyone simply replace the valve and continue using the tire. I'm worried that I may have caused internal cord damage that isn't readily apparent.
This time I think I'll put on all-metal 90 degree valves that tread on from the bottom.
What valve stem failed? Manufacturer? CAn you see why it failed?
Kurvy Gurl valve stems are a great brand to use.
total flat from 90 mph? with the front? personally, i would change that tire.
what a terrifying experience, and good on ya for getting her stopped without any more drama. i had a rear go at similar speed, and by the time i stopped it was very hard to keep upright. couldn't imagine what it would have been like with a front.
Details, I want details!! :smile: I, too, would like to know what kind of valve stem, and how it failed.
When you pull the tire to install a new valve stem, you should be able to see if there is damage to the tire. Look for rubber dust inside.
My last bike, a Multistrada, had very nice solid 90 degree valves. I asked my Honda dealer if he had any valves like that when they were mounting new tires for me. The pictures show the aftermarket pieces they had. I thought they looked cheap, but I was in a rush to get the wheels back to my bike, so I took them. I've attached photos. The rubber ripped where it passes through the rim, leaving about 50 percent of the remainder attached. The dealer now sells the Ducati valves.
  • [image: IMG_0211.JPG]
  • [image: IMG_0209.JPG]
Where are you in ATL? I'm in Lithia Springs and I have Bridgeport (Like Veefer Posted) valve stems and a changer.
My VFR failed inspection for bad stems. I told the donkey that they were good. He insisted. I put new stems on and the rear one failed 5 miles later. Good thing you can replace them without taking the wheel off or I woulda been more pissed.
What are ducati valves? A Ducati wheel needs a different size valve stem that does not fit a Japanese wheel.
A valve similar to the 90degree valve stem in your first pic is also used on Goldwings, but it comes with a support that prevents it from bending due to centrifugal force.
The Bridgeport valves are the way to go, good quality and low weight.
End of thread · 10 posts recovered Wayback Machine snapshot 1 Nov 2013
