Power Commander Maps Coderighter 6.6.12
2 posts Started 31 Oct 2012 Last recovered post 15 Jan 2013 Wayback Machine snapshot 19 Mar 2013
File Name: Coderighter 6.6.12
File Submitter: coderighter
File Submitted: 06 Jun 2012
File Category: Power Commander Maps
I have not changed anything on the bike that will effect the file since the last version, it's just a further refinement thru multiple trim acceptance and tweaking. There's been some confusion about version numbers, so from here forward, the version is the date posted on VFRD. Enjoy!
Click here to download this file
I also have PCV/Autotune in my '06.   There is a weak point in this map. In the fuel map of the 2nd gear between 2.5K to 5K and 10% to 15%. There are ups and downs in fueling up to 30%!!. In case someone would like to use this map without Autotune installed, I think he will experience surging.    This is probably an effect of PCV/Autotune and seems like standing waves. I have the same effect mainly when driving in the city.  In the countryside it is not so strong.  Maybe Dynojet should update PCV narrowing Autotune readings only when throttle is steady, as it seems that there are readings here during acceleration and fuel cut.   Another interesting point is that there are corrections in fueling of 6th gear for 12K rpm and even 13K rpm.  The real speed there is about 175 mph and 190 mph. Is that road readings or dyno?
End of thread · 2 posts recovered Wayback Machine snapshot 19 Mar 2013
