I am installing a Power Commander V on a 2006 VFR and have a question.I am disabling the PAIR Valve by blocking the hose connections indicated in a prior VFRD post concerning using a marble to block a hose. I have included 2 pictures to indicate the tubes I have blocked with vent caps and want to verify that these are indeed the only holes I need to block in order to disable the PAIR. I have Leo Vince exhaust and the stock air filter and will try the Power Commander Leo Vince map as well as the Coyze 06 map to see which gives me better results. Just looking to verify the PAIR blocking is correct before I button her up and take her out for a test ride.
[image: post-24160-0-33270000-1355544460.jpg]
[image: post-24160-0-80240600-1355544475.jpg]
