Trying to install an adjustable lowering link (bone) on my bike. Instructions specify that the center from hole to hole in the bone should not exceed 5 1/4". I saw another post on the Internet with a bone that was not adjustable, but the center hole to center hole was 5 1/2". Is it worth the trouble to change out this bone if I will only gain 3/4" if I follow the bone manufacturer's instructions? Any other guidance?[image: post-26845-0-57250700-1361736907.jpg][image: post-26845-0-57250700-1361736907.jpg]
Lowering 2006 Vfr800
Look up "triangle mod" in the forums. Your 6th gen connects its linkage via an 2 isosceles triangle shaped piece of metal. If you rotate that 60 degrees, you will get a 3/4 inch drop without changing out the bone. Also, if you need a major drop, you should look at these guys: http://www.sigmacycle.com/. I used the triangle mod and ordered their sidestand to address the need for a shorter stand. I'm still able to put it up on the center stand at 3/4 inch down. I doubt that you could still get it on the center stand with a larger drop.
Thank you! Good info! Will give it a shot!
Im 5'6". And i had lower the bike, IM happy with my result.
I rotated the stock triangle and swapped the adjustable bone and the side stand.
I used the ítems from this guys:
http://www.soupysperformance.com
Great customer service and support, i had mine shipped to Spain.
Sent from my iPad using Tapatalk - now Free
kamaleon, 10/11/2013 at 3:39 AMIm 5'6". And i had lower the bike, IM happy with my result.
How did you lower the front? Dropping the triple tree? Did you have any instructions? I’m trying to find instructions on how to lower the forks in the triple tree. Any help would be appreciated!
