Vfr800-A9 Vtec - Pcv And Autotune
1 posts Started 3 Mar 2013 Last recovered post 3 Mar 2013 Wayback Machine snapshot 19 Mar 2013
Hi folks
I have a VFR800-A9 Vtec which I am planning on fitting LeoVince cans too. I already have a PCV and an Autotune ready and waiting to fit to the bike, however I was wondering if someone could help clarify something for me please?
The closest base map I can find is "M16-005-502" which is for the European Model (i'm based in England) with Scorpion Exhausts, but the AFR in this map runs different AFRs throughout the Throttle % (13.2/13.5/13.7).
What figure should I be setting the AFR on the Autotune, or should I leave it as the Dynojet base map has it set?
What I am looking for is to smooth out the rev range, and if possible increase the MPG whilst cruising in 6th gear.
Thanks in advance
End of thread · 1 posts recovered Wayback Machine snapshot 19 Mar 2013
