Ok, so I really have no idea how old the battery I have in my '03 is. I purchased the bike about September of last year. Anyway... the start of things:
Before I parked the bike for the winter, by friend took it out for a day trip. I think the temps were in the 80's or so that weekend. On his way back home, the bike wouldn't start. All the lights came on, but would not turn over. He push started it, and it fired up. I guess a little later sitting in traffic it just died on him. It did this a couple more times, and each time he had to push start it. He finally got it back to my house, and I parked it for the winter.
I started doing some research and read that during the summer you could possibly kill a weaker battery with the stress of the electrical requirements (or something to that effect), because with the headlights on, the tail light, then the fan kicking on and off, and then the added brake light and turn signals.
Fast forward to today: I let the battery sit on the battery tender off and on for the past month. Each time I go out to check the voltage, it's around 12.3-12.5. Most times it fires up. Today, after letting the battery sit for 2 days on the tender, I took the battery to Autozone to have them load test the battery. the guy said it seemed to be fine. So I took it back home and put it in the bike. Checked to voltage, and it was about 12.5. I turned the ignition on, but did not start it, and watched the voltage drop to 11.5. I tried to fire the bike up, but no dice.
I'm curious if that is a normal number, or if my battery is indeed toast.
Sorry if that seems like along post, but I'm, still new here. :)
