Installation Issue With Staintune On 4Th Gen - Missing Bracket
8 posts Started 14 Mar 2013 Last recovered post 17 Mar 2013 Wayback Machine snapshot 19 Mar 2013
I was able to get my hands on a used High mount Staintune exhaust for my 1997 VFR750.  Looks good after polishing it up a bit.  Some minor scuffing and scratches.  There were no other pieces that came with this exhaust so I emailed Staintune in Australia who responded immediately.  They were kind enough to send me a check list of what usually came with a new exhaust for this model.
It seems some bolts, flat washers and spring washers were missing which I can get from the local hardware store.  It didn't come with baffles but Staintune says they are still available if I want to order one through them since they are used across other exhausts.   The one missing piece that has me wondering is a bracket that supposedly connects the bracket on the back of the exhaust to a mounting point up under the plastic below the seat.
This mounting bracket piece is discontinued so I am wondering how to best secure the back end of the exhaust to the bike.  Staintune said I would have to fabricate some piece but I don't even know what that entails.  Is there a simpler solution?  Any other advice would be appreciated!
It's nothing but a piece of flat stock bent to fit with two holes in it. A lot of folks don't even use it because where it mounts on the foot peg is so solid.
Good luck!
^ Agreed, just bolt it up at the flange and at the footpeg and call it done.
When I had one I found it was often easier to fit if I loosened the footpeg bolts where it meets the subframe, then tighten the flange, footpeg-to-muffler bolt, and footpeg bolts, in that order.
Thank you guys...glad to know the exhaust wont go flying off without that piece!  I also appreciate the install tips.
Bad news.  i'm afraid it won't work without that piece.  I will PM you my home address so I can properly mount....I mean properly discard it for you.  Just kidding, man.  I haven't heard one of those on a 4th gen but I bet it sounds great!  :biggrin:
Chuck
Chuck
LOL you had me for a moment as I started to read that.  I will try to get a clip up after its installed.
Sounds like it mounts the same as the 800 version I have, and I'd agree with the above. I think either would work fine solo, i.e. if you had said bracket and didn't want the passenger footpeg, or didn't have the bracket and just used the peg mount.
Don't forget that the stocker mounts only to the peg, and it's way heavier!
A few questions about the install...
Does anyone have any suggestions for what type and size wrench to use on the bolts to take off the clamp connecting the exhaust pipe?  What about for the bolt connecting the passenger foot peg to attach the new exhaust?
The bolts for the clamp seem in a tight space and couldn't get the wrench that I had in there.  I started to see if I could also use the wrench on the passenger foot pegs but the bolt was soft and I stopped because I was starting to round the edge.
End of thread · 8 posts recovered Wayback Machine snapshot 19 Mar 2013
