I am now officially in the club. What club? I dunno, but I have a VF500F. 1984 and its a runner! Paid a dollar a cc and I think I love it. This may change, lets hope it stays in the honeymoon stage.
Let me what I got in the way of matching plastics that I can part with...I may have something that matches the tail/side pieces and we can work something out.
I am slowly talking myself into the idea of giving up the lockhart full front fairing with pristine matching plastics and solo rear seat cowl even though I have only seen three of those rear cowls in the flesh in 25 years...
We would of course need to have something notarized with regards to any flat black spray bombs and mandatory 75 meter restraining order...
ps, if Yoshi doesn't pick up his new track bike soon I know where you can get a great set of wheels and shock to make this lil 500 handle like a dream. :goofy:
Nooooo, don't you dare paint that bike flat black. Be patient, you will find the matching parts it needs. Original paint is worth MORE too. These little 500's are great for tight twisty roads...just no top end....none....nada....zilch. lol
NakedViffer
When I very first glanced at this, I thought you had painted the Seca RWB, hahah. Is it time for some flat black creativity?
not entirely true, when I weighed about 158 I topped one out at 124 mph ... today the 25 year old engine rings/valves combined with 25 years of onion rings would probably limit me to bouncing up against the ton and struggling to punch through 110
And you did that without a gun, Jesse? Nice indeed. Among my clutter is its' 1/2 brother; a VTR 2 fiddy. We call them BarbieCeptors here. If it were matte black maybe it wouldn't be so girlie looking. Good fortune, R3~
when I finally get the Seca running correctly, I am going to ride it back and forth to work until it explodes. I am going to un-ass my Guzzi though. Anyone want an Italian project?
I live with an "Italian project" so NO I'll stick with one at a time!
Well done! Careful maintenance of the valve lash, selecting a top notch motor oil and filter, proper engine warm-up and keeping the revs in check (the hardest thing to do) are all keys to owning a 500. They're great bikes but definitely not a 'set it and forget it' type of engine. Good luck and have fun!
V50: Do you know anyone on the Guzzi list? There are a few truly dedicated fanatics in MD. If you don't have a connection PM the details and I'll re-route them to 'persons of interest'. I have a Daytona, LeMans 2 and a 1000 and an '87 V50 III. R3~
I had to sell My 1000sp and my Lemans MkIII during hard times about 7 years ago. Broke my heart. PM sent.
Just for a goof, I sprayed carb cleaner into the intake snout and hit the button. Idled just fine. I hope it does the same with actual gasoline!
That's great news Timmy!...I should be able to sort through the plastics I have and see whether I have a set to match your tail/side plastics or whether I have to move the full set on to you...
you may make enough to purchase a very nice set of matching plastics along with both the smal chin fairing and period correct Lockhart Phillips full lower...the jury is still out on whether or not I toss in the very rare rear seat cowl and latch (in matching factory colors as well) but the Richard remark has me leaning towards yes. :goofy:
Aftermarket systems for the 500's 360d V4 engine are tricky in terms of performance. Most (if not all) actually rob power over the stock system*. Of course they look nice and sound nice.
I think for a solid system $150 is a good deal so no worries.
A little more info:
The Yoshimura and Hindle systems require the removal of the centerstand. The V&H does not (it does require an easily fabricated stop for the centerstand) .
Also, the Yosh system looks to have been designed for the shallower '84/'85 oil pan - not sure about the Hindle or the V&H, or if versions of the Yosh, Hindle and V&H were made specifically for the '86.
The Daytona has gotten to be a lot of motorcycle for these eighty year old bones. But some how when that thing clears the garage doors we can do almost anything. VFR 'people' remind me of Guzzi people, unlike any other brand mc owners. Great folks no matter how you contact them. Good fortune, R3~
got he carbs off with a minimal amount of bloodshed. Now a good cleaning and research into start points with rejetting and on with the new boots. (I have come to the conclusion that all bikes in the known world need new boots!)
I really want to time this with the arrival of the exhaust to minimize the on-off of the carb bank. I am hoping for a miracle, so I can do it once.
Yeah I remember those days, first time was when one of the fiber fuel tubes that ran in between the carbs crack and started leaking fuel on the motor. Of course Honda replaced the plastic tubes with metal ones.
You may want to double check the numbers on the carburetors to confirm the year.
On this note all the years are slightly different with the '84/'85 having the larger bore. The emulsion tubes, needle jets and jet needles also vary over the three years. It is another puzzling (or maybe endearing?) quirk to the 500.
If thinking of rejetting keep in mind this isn't the easiest thing to do on the 500. You'll need plenty of patience and if possible a friend with an EGA.
While servicing the carbs remember to check the float height. If you don't yet have a FSM it is a must for the library shelf.
New boots & a few tricks are key to the reinstall. No hammers required!
Yeah and make sure the fuel tubes are metal and not plastic and if they are replace them now. Oh yeah dont loose those little springs, they are VERY important.
Yeah and make sure the fuel tubes are metal and not plastic and if they are replace them now. Oh yeah dont loose those little springs, there are VERY important.
Not 100% on this but I believe 6061 alumInum fuel tubes are only available for the larger displacement Interceptors not the 500.
My 84 Magna was one of the first to arrive in the states, the third winter I had it I went to start it and it back fired. Didnt think anything about it, spring time arrives jump on the Magna head to the mountains, the first red light I stop at and wow the gas smell was over whelming. Look down and pant leg and it is wet, yeah you guest it gasoline. Stop and had to load it on a pickup truck. I think well I know it was caused by the winter back fire(crack one of the fuel tubes right past the oil ring). Long story made short the dealer did me a favor(HaHa) and gave me the metal fuel tubes and did me another favor by letting me install them. 6 months later Honda
did a in house recall on any V4's that developed gas leaks.
and being older and wiser....I just ordered a jet kit. The though of home-brewing all that individually different jett and needle and emulson tube for each carb made my head hurt.
Take a photo of it when it arrives and post it please.
Also, on the emulsion tubes, my take is that these follow the needles. I'm not 100% on this though as I have seen a few sets with crisscrossed emulsion tubes..
[image: jetneedlesandemulsiontubes10-20-10.jpg]
[image: 84origcarbsmainjetemulsiontubes410-18-10]
[image: 84origcarbsmainjetemulsiontubes110-18-10]
[image: fsmcarbschematicdwgnote10-18-10.jpg]
[image: vf500fcarbspecs08-10-10.jpg]
I'd be curious to know what you find when you disassemble the set you have.
I was going to ask you about all that, so extra thanks for compiling it for me. I'll let you know how mine carbs were when I get the bowls off later today.
Don't have the numbers to compare the 500's stock system (mufflers & collector box) to an aftermarket system.
I have a hunch stock is about 130% heavier in general.
This said, the stock collector box does a good job of evening out the exhaust flow where aftermarket systems can muddle this a bit - most designed for top-end performance while sacrificing the mid-range.
I secretly want this bike at least running well by TMac. If CornerCarver ever gets his finger out, I may not need any paint. (but i will have to sign a "No flat black" clause to seal that deal. I guess it will all depend on how well the re-jet goes. If it is anything like rejetting a SECA II, then it will be ready for TMac 2015. The carb bank is soaking in pine sol as we speak, and should be well clean in time for the new internals and exhaust.
I am afraid that it wil end up like "biker buildoff" where I am assembling it the night before. Not to mention, I have to ride it 4 hours west to hook up with my ride down. 4 hours of thinking "did I put that back on right??......"
Yeah thats not fun and if you screw up on a mc rebuild it could hurt BAD ....
on the other side of the wall to the right is a veritable junkyard. Addition is in planning stages.I wish I could keep crap of the bench, so I could use it! BTW, my other, home made "enclosure" is still standing after a tornado and 2 hurricanes.
I got home last night from my business and spent the day working on other crap.
I will send you some pics tomorrow, it's the least I can do since you have already purchased, paid for and received an exhaust while i have been just talking about plastics? Plastics? You talking plastics? (say it in an Allen Iverson tone and it gets funny-ish) I mean you not talking about the game, right, you just talking about plastics?
after coming out of a 2 day in-bed sickness, I discovered that the problem was that the petcock flowed really slowly and that is why the 2 right jugs were starved of fuel. That has been solved BUT, I still do not have a title and I keep thinking about the court appearance where the judge says "Sergeant Steffes, you should have known better....", so I AM loading up the Yellow Peril for the trip.
This is double bad news because I wanted everyone who wanted to have a go, to be able shriek around on that little rocket. It kinda negates all the sleepless days working on it to get it ready in time, but what are you gonna do, right?
I think I will drink some gin and then go bid on El Caminos to drown my sorrows.
Eventually you are going to take it to court (to get the title, I presume). Why wait? You're going to have to anyways. At least this way you know if you have a street bike or a track bike.
Also, there is that go-kart track behind the motel that may be big enough for the 500, but would require on-site testing. :fing02:
Spoke with Timmy last night - I believe the issue is that if the bike were to get impunded in NC for no title, the ONLY solution would be for the previously titled owner to show up in NC to gather the bike up. That wouldn't happen - so Timmy would be out a bike (long term) and depending on when the impound happened during the week that we are there - he may be riding a lawnchair at the motel for a few days while the rest of us are riding.
The Yellow Peril is the better choice given the circumstances.
I'm meeting Timmy about an hour south of Pittsburgh in Morgantown WV, and then we're loading his bike up from there. Couldn't really get 3 bikes on my trailer - it would be close to overload with that weight - and for a long trip - not gonna do that.
I love the motor. Very revvy, and the torque curve is a straight slant up. The power is near the same everywhere, so you do not have to pin it all the time. Really like it!
So, did you get an El Camino?? If so, we need pics!!!
C
PS Sorry about all that hard work going to waste...
Timmy - upper respiratory deal knocked me down for a couple days this past week, too... Sickest I've been in a long time. Glad to have the worst of it out of the way.
I ate lunch at El Ranchero and my 3 enchilada platter came from a kitchen that probably hasn't been cleaned since '72...see we really are two side of the same coin :biggrin:
