I'm looking for recommendations on a map for my power commander 3 . I have a k&n air filter and Delkevic high mount with the spud removed. This is the map I'm currently running. seemed like the closest match to my setup.
2000-2001 Honda VFR 800 European model Laser Duotech open slip on, no insert Stock or aftermarket air filter O2 eliminators installed So which map are you guys running?? Thanks Jess5Th Gen Pciii Maps Suggestions
I think your analogy is a little flawed. it's more like having a handful of darts and trying to find which one is best weighted for you. Add to that the fact that dyno tuning around here is 100$ an hour I'm willing to try a few out and see what I like. Have you ever posted up your map for others to try?
Jess
Jess
My dynotuner is trying to make a living building and tuning sportbikes. I would feel like a cheater - or worse - if I shared his map.
Well I don't mind sharing the map I've been using on my 2000. It is supposed to be for a euro model.
I can't remember where I got it from but it is working well for me.
Pulls smooth right through the rev range and gets great gas mileage as well.
I'm like you, not everybody can afford stealership dyno tuning.
- [image: Attached File] staintune_european.djm 3.88KB 13 downloads
Thank you, that sounds similar to the map I just installed. May give it a try!
