Well. To be honest, I'm not really sure. Around the thirteenth or fourteenth hour of fault hunting in a dark garage by yourself, you enter a sort of Heart of Darkness like experience of increasing bizarreness and desperation. The thoughts you are thinking seem to be intelligent and rational, but after sleep and re-exposure to other people...
I decided to check the ignition circuit since I had no spark. As I took the bike's front fairing apart, the problems got worse: no spark, then no fuel injection, then finally no fuel pump as well. I decided to check the engine cutoff relay. It was not relaying. Sweet! But before I shell out some money to buy a new relay, I tested the relay by connecting it straight to the battery as described in the manual, and voila...it worked fine. Crap. I decided to check the voltage in the circuit from the top down. Started at the bank angle sensor, then the engine cutoff, then the fuel cutoff, then the kill switch...and they were all showing 12.5-12.3 volts. I was confused. How could there be 12.5-12.3 volts at every connection in the system, but the relay not work?
Well, if I had paid attention when I was a child, I would have known the answer. To explain, there are two types of people in my family: electrical engineers (My dad, and my brother) and liberal arts majors (my mom, my other brother...and me.) So I bit the bullet and called Dad, and explained my process, and he laughed and pointed out that I was testing voltage from each point on the system to the ground lead of the battery, so I had verified that power was available all the way through the circuit, but the circuit was not complete because I hadn't checked the grounding of that circuit--by grounding to the battery terminal for ease of testing, I was bypassing the circuit's ground. Then he said something about how if I had paid attention during the eighty billion times he dragged out the voltmeter to work on the car or washing machine or furnace, then perhaps I would not have these problems, and maybe I should have studied something more useful in college than Political Science.
Actually, he was really nice about it.
So I went down and measured voltage across the leads of each relay and the bank angle sensor, and none of them had any voltage. So I ran a tester lead from the battery ground and touched it to the ground lead of the bank angle sensor, because that was the only ground lead I could find in the wiring diagram for the ignition circuit and WHAMMO! Lights came on in the instrument panel, the fuel pump whirred to life, the relays all clicked and I started singing the hallelujah chorus. I checked the voltage to the ignition coil, and it was there, so this should solve the spark problem (unless all four coils went bad simultaneously).
I tore apart the wiring harness and this is what I found:
[image: Mobius Strip]
Mobius Strip
Previous Owner, my God have mercy on his soul, apparently decided to rewire the R/R into what I can assume is a dedicated circuit. My best guess is that the ignition circuit was grounded and powered through the R/R ground. PO (mGhmohs) then installed a new R/R and a new wiring harness, but didn't know what to do with the old harness...so he cut the wires off the R/R and looped them to each other and electrical taped the whole thing up and said f*** it, let's ride. Oddly enough, the quality of the work is high: copper crimping, no corrosion whatsoever, purple patch tape over the crimp spots, electrical tape and heat shielding over it all, and routed carefully, with OxGuard on the connectors.
So here is 12 or 10 gauge ground wire, run in a loop to itself, with a connector in the middle of that loop, and it goes to nowhere. They are tied independently into the small green ground wires from the ignition circuit and headlight circuits. Also, there is another deviation from the wiring schematic: there is supposed to be a small green ground wire going through the gray 16 pin connector from the ignition circuit back to common ground on the bike, but it is not there. There are only 15 wires in that connector, when there are supposed to be 16. So there is no direct path to ground for this circuit.
Instead, the whole headlight, high beam, and ignition circuits are currently going to ground through a green/black wire that grounds out the instrument cluster. All that green ground wiring in the picture is joined into one itty bitty green wire through that yellow junction block. That one ground wire goes into the instrument panel, where it encounters 110 ohms of resistance before connecting to the instrument panel ground wire, which proceeds with 0.4 ohms of resistance through the 16 pin connector and on to the chassis ground.
My best guess is that there was a connection in the instrument panel between the ignition circuit ground, and the instrument panel ground, and when the PO realized that the ground was working after rewiring the R/R, he said, "F*** it, let's ride!" and our inadequate little Horatius on the bridge heroically held out for eight or nine thousand miles and now is so fried that he can't hold on any longer. The connection is there...you can get from any point in the ignition circuit to the ground, but you have to go through 110 ohms of resistance to get there. Dad did a little very rough guesstimation over the phone and decided that we are looking at something in the realm of 100 amps to make that circuit work against that resistance.
All the wires in the ground are internally continuous--no resistance. The only resistance is between the leads on the instrument cluster where the green wire goes in, and the green/black wire comes out.
The red/white wires are tied to themselves, with a smaller red/white tied in, which leads to a fuse, which leads to a green/yellow wire that goes to one of the headlight relays and doesn't appear to carry any current. I have no idea what it is for. There's also a white/black wire tied into one of the red/white ones, which goes to the connector, but there is nothing on the other side of that connector for it to connect to. It's a very lonely connector.
Since I can see no point in any of the large green/red and white wires in that loop, I'm going to chop them off, wire in a nice phat 10 gauge ground line to all those little green wires, and run that independently back to the chassis ground underneath the seat. Then we'll see if she fires up. I'll probably test the R/R and stator while I'm in there as well. Just to be sure. VFRness is due to come in the mail today, so I'll stick that in while I've got the whole thing torn apart. Hopefully the custom harness job isn't so hacked that the VFRness won't install...
Edited by baraka, 21 August 2013 - 09:53 AM.
