I have bought a 2002 VFR800. Big deal, you've probably all got them...
This is mine:
[image: DSC_0231.jpg]
I didn't take it apart, I have no experience with them & there are a few vital parts missing.
I am very good at Lego however :goofy:
(That, BTW, is the best smiley I've ever seen.)
Some googling tells me all those parts, plus the slightly important missing parts, add up to about 260kg :huh:
Something will need to be done about that. The bike will be a trackbike, so light weight is the name of the game, also low budget! Mostly low budget. Minimal engineering would be ideal, I don't have anything too advanced, nor could I really be bothered. Bolt on parts are good.
(What have people got these down too without carbon fibre washers & titanium lug nuts?)
The subframe has to go. Or go on a diet. The linked brakes need to go. PAIR needs to go, but I think that is sorted. SSSA should stay, despit being heavier than a regular swingarm (low cost remember). The front end needs to be replaced, Ideally with a USD R1/R6 front end, with Radially mounted Goldspot calipers & matching Radial M/C... :goofy:
Hehe... Where was I? Oh yes, budget will proabably dictate an F4i front end if I can find one cheap enough, or even a Thundercat front end... I will be looking for cheap parts at all time of course.
:offtopic: The (IIRC) 2001 master cylinder from the R1 is a cast Brembo unit, I run it on my TRX with the non-radial Goldspot calipers, from my research they should be functionally the same as the radial mounted version, same piston part numbers you see ;)
Ok, down to brass tacks: I am missing an ECU, rear wheel, exhaust headers & various other small bits & pieces, I intend to buy these as cheaply as possible as I go, starting with the most important, which I'd say would be the ECU, then headers. Ironically, I have found a cheap ($40) VTR1000 subframe which may work. The best laid plans hey... Or in this case barely thought out ones.
Step 1. Clean shed. This happens rarely. Don't ask.
Step 2. Move this:
[image: DSC_0240.jpg]
(if anyone knows a source for headstem bearings that don't exist because the inner dimension is impossibly close to the outer dimension to work, I'm all ears!)
Step 3. Add Engine
[image: DSC_0248.jpg]
& that's it for now. I need to do the valve shims on the engine, add a clutch cover gasket, then start cleaning the engine & swingarm & do a stocktake. Ideally I'll find an american ECU while this is happening & sell off some superflous parts to pay for it.
