Just received my first e-ad today for Pilot Road 4s. Now, who will be the first to try them? I probably won't put a new one on until May for the MSTA STAR ride in June.
Pr4s are here
Standard, for all around sport touring use.
GT, which offers a stiffer casing for heavier bikes, riding two up with luggage, etc. These are going to be the standard issue tire for the BMW R1200 RT.
Trail, which is NOT an off-road tire, but a tire designed to be used on trail bikes that are ridden 100% on the road. The main difference in the trail version is the compounds are softer in the rear.
Sent from my LT30at using Tapatalk
Kimball will be the first, probably already has a set.
I just put PP3/PR2 combo on in September last year so I'll have a while before I'm ready for a set. The PR4 rear looks like a combination of the PP3 (tread pattern) and PR3 (x-sipes).
Sent from my SAMSUNG Galaxy SIII using Tapatalk 2
What about using the pilot road gt's for a 4th gen in that they don't make a PR 4 in a 170, whereas they do make the PR 4 gt in that size. My pilot road 3 rear is toast (couple of skids today on the Sunday Morning Ride) and I'll have to get something that'll work w/ the PR3 front. I only got about 3000 miles out of the rear,mmm , maybe I should go back to PP's I got @ least 2500 mi and they stuck much better than the PR3's
Wow wonder why the low mileage? I have 5k miles on my PR3s and they look fairly new. They have tons of life left in both front and back.
As far as stickyness, this was taken yesterday. I haven't had an issue!
Looking forward to getting PR4s when these finally wear out..
The PR4 do look tempting, I guess its a evolution of the PR3 that might not been as good as the PR2 in all areas. But locally the PR4 is very high in prize, actually you get a set of the first gen PR for same money as a PR4 rear! So for me the first gen PR is more tempting as budget is low and the bike is on the sale list.
Any other feedback on the PR4? I'm looking for a new set but read the PR4 rear is 20% hard/40-40% medium compound, where the PR3 was 80% medium/10-10% soft. Front compound distribution appears unchanged.
Michelin improved the front tire a bit over the PR3. Some riders complained that the PR3 front was "squishy" in the corners. Michelin also beveled the edges of the siping on the front tire. You have to look really close to see it. Overall the tire stops a bit shorter in the wet and dry over the PR3. For the minimal price difference, I would go with the PR4. Michelin is keeping the PR3 around for awhile since they have sizes that fit some of the older ST bikes.
If you have a VFR 1200, the PR4 GT is the tire to get. For the 5th and 6th gens, the regular PR4 should be fine even if you are carrying a passenger and loading the bike down.
Very happy with the Pr4's,they get well tested on the roads over here,lots of rain at times.
That's amazing. They look like they have quite a bit of life left in them.
Damn, 42 psi front??? SKETCHY!!! Your bike is only rated for 36 and if you call Michelin, they'll probably reach through the phone and slap you. I have about 12K miles plus on my old PR3 front and I have only ever run 36 up front. Air that down, save yourself!!! That ain't a tire at that pressure, it's a ski!!!!
It seems Honda has generic tire pressure of 36 PSI for the front in most of their motorcycles (Goldwing, cbr 1000, st 1300 etc.), My last bike was Kawasaki Concours 14 recommendation was 42 PSI front and back. Remember VFR 1200 is a heavy bike and I'm trying to maximize tire life by using 42 PSI in the front.
Edited by Dae, 26 January 2015 - 06:17 PM.
My St1300 has 42/42 for pressures and they work great with the sets of tires I have used .Dunflops/pirellis and last michelin 2s but lasted 25000 kms .
ST 1300 was one of most comfortable motorcycle I have ridden with a huge gas tank. I have 152,000 KM on my VFR 1200 and probably ST 1300 would have been a better choice for me.
I didn't notice that you were riding the 1200. Never mind... :mellow:
