4Th Gen Exhaust Pics
6 posts Started 12 Jan 2014 Last recovered post 12 Jan 2014 Wayback Machine snapshot 14 Apr 2016
Can someone with a 4th gen stock exhaust take some pics of what she looks like from underneath?  I'm considering ditching my collector box, but if I do, I'll move to a non-standard exhaust.  Maybe 2 GP style shorty's, maybe something else.  But first, I just want to see what things look like from under there.
Ideally, I'd like a pic from underneath (do you 4th genners have a centerstand?  I know putting on a 4th gen exhaust on a 3rd gen requires a delete), one from the front, behind the chin fairing, and one from inside the rear wheel (prefferable with a ruler showing engine/swingarm/tire clearance).  Of course any other pics would be appreciated.
TIA
Are you sure you are talking about a 4th gen bike.
The 4th gen does not have a "Collector" or "Boom box" (as some would call them).
All it has is an enlargement of ID/OD of the pipe where the four separate pipes meet under the bike and connect to the muffler can section.
The 3rd gen on the other hand did have a collector/boom box (which I think must act as some sort of resonator) that I think some eliminate by installing a 4th gen system to replace it.
Are these any good? They are the closest to your request that I have. There are several more. I refurbished my '95 FR exhaust in 2005. It had a centre stand as in the pix.
Two years later the tail of the collector cracked. I repaired it before replacing with a Motad - excellent UK kit. I've still got the rusty bits hanging in the garage!
If you remove the pipes, get the bike raised on blocks about 8" then the pipes can twist enough to come out without removing the centre stand - or at least they do on a 4th gen..
  • [image: Refurbished exhaust 009.jpg]
  • [image: Refurbished exhaust 011.jpg]
  • [image: Refurbished exhaust 012.jpg]
  • [image: Fit Motad 24Mar07 011 small.jpg]
Beck, I have a 3rd gen, and I'm looking to lose it.  Sorry for the confusion.
Steve,  Those pics are what I'm looking for.  Seeing them on the bike helps give everything perspective.  TY
More pics as always encouraged, but this is a great start.
IIRC, the switchover to a 4th gen system could mostly be a "plug and play" situation.....
There should be enough threads existing in the archives here that discusses the switch in detail. Try to do a search....
I'm not looking for a how to.  If I make the switch, it will include modifying the stock 4th gen headers to something custom.  I just an idea of where things are in the stock formation to see what may be required.
End of thread · 6 posts recovered Wayback Machine snapshot 14 Apr 2016
