#1 AnikMankar Thread starter 5 Mar 2014 11:33 Hi
have purchased a custom instrument cluster/faceplate. Any one has changed these ? anything to lookout for before i dismantle it.
* alignment of the Zero ?
* removal of the needles ?
do let me know guys - thanks in advance
http://i.ebayimg.com...i 8Q~~60_57.JPG
Anik
Hey Anik
There was a member on VFRW that replaced his gauge faces with ones just like those in your link. As I recall, he didn't have any real issues with the swap. Check out the link.
http://vfrworld.com/...New-gauge-faces
#3 AnikMankar Thread starter 7 Mar 2014 02:47 Thanks that helps a little. Didn't see any write up on how to align the needles
Hi they look sweet.
Who is the seller out of interest?
#5 AnikMankar Thread starter 21 Mar 2014 04:49
Hi they look sweet.
if you are referring to the back plate - they are on eBay. I am planning to incorporate a volt meter in there also. Not yet received the volt meter, untill then...
Hi they look sweet.
Yeah it is the backplate. Do you know who the seller is, can't find them.
#7 AnikMankar Thread starter 21 Mar 2014 18:56 Check item 330972621799 on ebay
thanks Anik
I don't know how I missed this but I could have helped; but looks good anyway!!
this is a shot of mine.
[image: med_gallery_19344_5942_55124.jpg]
[image: med_gallery_19344_5942_185709.jpg]
Hey v4pilot
What is the "0" located in the bottom of your gauge cluster? Is it a gear indicator, or voltmeter perhaps?
Yep it means its in neutral at the moment; I stuck a gear ind. where the neutral light was.
#11 AnikMankar Thread starter 14 Apr 2014 04:44
done something similar but not as clean as yours. Have placed it outside . Still needed the Neutral light to ensure i have the gear in that position
[image: IMG 20120116 00123]
IMG 20120116 00123
[image: IMG 20120116 00124]
IMG 20120116 00124
#12 AnikMankar Thread starter 14 Apr 2014 15:35 My plan is to put the voltmeter in the faceplate.
These are the custom plates I got ...
thanks Anik
[image: u9ahu9yr.jpg] [image: 9ymupy9y.jpg]
Will figure out which Looks the best
thanks Anik
thanks Anik
[image: uploadfromtaptalk1397489649607.jpg]
Are you sure that will fit behind the the tac ?
#14 AnikMankar Thread starter 15 Apr 2014 02:11 These are about 4mm thick. Would require some alterations. Will know only after I take them apart.
Have searches around for good pictures of already opened up instruments. Quite difficult.
thanks Anik
#15 AnikMankar Thread starter 15 Apr 2014 18:26 Some progress
[image: atege2a8.jpg] [image: mebume5u.jpg] [image: 2e5useja.jpg]
RPM side. Didn't find any space or a good location for the volt meter. So installed the faceplate as is.
[image: asapapab.jpg]
Needle stop hole being too big, had to super glue that needle and secured it with some silicon on the rear side.
[image: supepu7y.jpg]
Rpm side completed
[image: byguqapy.jpg]
Speedo side top side has some place
[image: na7yqy9a.jpg]
Photo copy of the speedometer faceplate helped to create the right stencil and position.
[image: bagatane.jpg]
The unit underneath is protruding out so had to move the volt meter up by 1mm
[image: 4e6abaqy.jpg]
The faceplate sits on a plastic light defuser. This spreads the light from the bulbs. Marked this plates also as it needs to be cut.
[image: ha3udegu.jpg]
Once Marked, masked the area as it needs to be cut off. Used a soldering iron to cut it off found it less messy.
[image: ahyzyzyg.jpg] [image: qytavu5y.jpg] [image: a4ebusy2.jpg]
Similarly the faceplate had to be cut of. This was tough as it is soft can't file or dremil it. Used a sharp blade
[image: vu2epa9a.jpg]
There is a slight gap and the light will defuse through the gap. A little black paint and silicon to seal it of.
More later.
thanks Anik
#16 AnikMankar Thread starter 16 Apr 2014 04:53 May look like this
[image: huqerety.jpg]
Voltage is of my adapter not the bike
[image: emoji1.png]
thanks Anik
Very cool Anik. Look forward to seeing the finished pictures.
Very nice. Can I send you mine and about 30 of my friends face plates .
Nice work ..
#19 AnikMankar Thread starter 16 Apr 2014 11:18
Nice work ..
sure anytime :) all the way to this side of the planet !!
Yeah a little expensive but good job !!!
