Quick Question
10 posts Started 6 Mar 2014 Last recovered post 9 Mar 2014 Wayback Machine snapshot 30 Apr 2014
If I place ends of volt meter on battery terminals of my 98 vfr800, what Voltage should I read at idle and 5k RPMs?
Last I checked mine it was:
Idle: 12.09V
5K: 12.19V
Idle - 12.7-13.2V
5K  - 13.7-14.2V
Those are my thoughts. If at 5K you're not seeing a jump in voltage, you have an issue with your charging system.
Thanks Yoshi, I knew I had a problem, just wanted to get a true sense of where it should be. I am changing my R/R Saturday, and then will check again!
What's the battery voltage read with everything turned off? If it is much lower than 12v you might need to replace the battery as well.
Check the battery first. --- Charge it overnite and get it load tested.
I installed a Rick's R/R from Tightwad on my 5th gen after the OEM started failing.  I  now get 14.3v to 14.5v from idle all the way to 5,000 rpm.  The electrical forum has lots of threads on diagnosing charging problems.
http://www.vfrdiscus...m/7-electrical/
Yea I have gone through those threads and it's hard to find someone just giving numbers and what it should be. I checked my battery before the winter when it started havin problems and it tested good. Charging it tonight, put a new R/R on it today, and will test tomorrow.
Just hoping it doesn't end up
Being stator! My end on last R/R melted inside the plug, end adaptor thing!
If you want a straight up step by step.... check this.............
Steps:
- Recharge battery overnite - then to take it to Autozone, Batterys Plus or similar to load test. -- Good? Bad? – An iffy battery can fake you out and act like a bad R/R. Buy new if needed.
- With good battery fire it up, warm up for a minute or two.
These are R/R quick checks---
--- With voltmeter at battery get voltages -- idle volts? 5000 rpm volts? What’s the numbers? Should be in 13ish min idle and in 14s at revs. If in the 12s at idle, try at 1900 rpm. (It’s not unusual for the system to be in discharge or no charge at idle.)
- Check stator
- 1. Pull connector apart. Set meter to resistance. Check pin to pin stator side, 3 yellow wires, A to B, B to C, C to A. What’s the numbers? 3 separate readings --Should be less than 1.0 ohms.  (Engine off)
- 2. Check continuity from each A,B,C pin stator side to ground, -- -should be infinity - nada nothing. no continuity.  --   3 separate checks. (Engine off, again connector is apart)
- 3. Crank it back up. Do another pin to pin thing, but set meter on AC volts. idle and 5000 rpms. What's da numbers? Should start 15 -20ish and climb 50ish and more.  Again – 3 readings stator side connector and still apart.
- Repeat hot.
This quick list will catch the obvious stuff, but if you need to dig deeper check this chart. (Some guys like this chart, my taste, I don’t care for it.)
http://www.electrosp...ing-diagram.pdf
Steps:
- Check stator
- Repeat hot.
So I am kind of a starter when comes to this but here are my findings.
I placed a brand new R/R in the system yesterday, charged battery overnight and today my DV Voltage reading at bike on idle, low
Beams was about 13.2V. When I rev to 5K it goes slightly down to about 12.9V.
I tried the stator test on the connector pictures below and got around 0.8 ohms on all tests.
Thoughts,? Dead stator? My connector on old R/R that went to yellow wires was melted inside...
[image: zy7ujery.jpg]
Here is what my old one looked like end of last year...
[image: tyhenegu.jpg]
You might consider a vfrness as its called.. heres a pic of the one i made to replace melted RR connector block and lines.
The standard honda ground goes into the middle of the rear loom which i suggest cannot cope well with the amount of extra discharge.
[image: IMG_0455.JPG]
So now i have two new earths, green, one for the frame, one to battery negative.  A new line to the charging input, red/white on the starter block behind battery and another positive, red direct to battery.. i also added a fuse inline after this photo to the new red charging line to battery terminal.
The 3 yellow lines are shorter as i removed the charging wires from the middle of the hot block to along the left to a remounted RR in the cool on the left rear side.  I assume the extra heat from the middle of the block is heating up the RR unnecessarily along the copper lines..
Power went from a sitting 12.9, 13.4 at 500 revs to 14.5 whilst engine running from 2000 to 5000 revs.
Battery(i now use a racing lithium item)  also now sits around 13.9 when engine off...  and so far no meltdown issues...
End of thread · 10 posts recovered Wayback Machine snapshot 30 Apr 2014
