#1 CBVFRbikeboy Thread starter 22 Mar 2014 09:57 Hi guys. Wondering if the vf1000r swingarm will bolt into an '83 vf750 frame? I have a spare set of R wheels I thought I'd try to fit in a spare frame I have. I need to have the caliper mount of the R to fit the rear disk. I think the front will be OK?
cheers
ian
#2 CBVFRbikeboy Thread starter 23 Mar 2014 01:40 Sorry. Just realised the brake torque arm connects to the frame, not the swingarm. Need a plan B :wacko:
cheers
ian
the arm does NOT go to the frame.. in anycase just put the wheels om the 750 swing arm.
Thought I saw someone who put R wheels on an F and used the lower right rearset bolt location to attach the (modified?) torque arm.
#6 CBVFRbikeboy Thread starter 23 Mar 2014 16:39 gll429 the arm does NOT go to the frame.. in anycase just put the wheels om the 750 swing arm.
Sorry, I should have worded that better. The 1000r arm is attached to the frame, and the caliper is underslung.
[image: vf1000r-brake.jpg]
need the 1000r caliper because the disk is smaller.
cheers
ian
Captain 80s Thought I saw someone who put R wheels on an F and used the lower right rearset bolt location to attach the (modified?) torque arm.
thanks for that. I'll see if I can find it.
cheers
ian
It was me and I used a longer lower bolt through the lower right peg hanger mount. The bike was a VF1000F not a 750 though.
VF1000RS
And then it was me copying you.
:cool:
Or you can do away with the arm.
[image: IMG_5399Medium.jpg]
vfrcapn
VF1000RS It was me and I used a longer lower bolt through the lower right peg hanger mount. The bike was a VF1000F not a 750 though.
And then it was me copying you. :cool:
I think I've copied a thing or two of yours as well!
