Hello, I am new to this forum.
My name is Manuel and live in Germany.
I just bought a VFR 800 ´01 with 35000km.
When accelerating it feels like it is the same if I open the throttle 100% or 75%, it just feels the same and I think there must be some power missing because when I drive in 4th or 5th gear (there it mostly happens) sometimes I get a short loss of power at about 9000 rpm. It only happens when having full throttle and only in this rpm area. When I say short, I mean its about 200ms. After this loss of power, the machine accelerates again directly. There is no light flashing or any other symptom of electrical problem. But maybe there is something wrong with the fuel or ignition system.
So I started measuring the sensors today and found something unusual (for me) when checking the TP-Sensor which is mounted to the throttle-system.
I disconnected the grey 22P connector from the ECM and measured the light-green and green/orange pins. In idle state I measured 840 Ohm and when opening throttle the resistance raises to 2,2kOhm, but at about 75% of the throttle the resistance goes down again to 1,7kOhm. For me this means the potentiometer is worn.
Could someone of you verify if the resistance is ok or not? In the service-manual they want to use a test-box which is only 2000€ in Germany without the cables :-) and I don´t want to disassemble the connectors to put wires inside to measure the voltage.
Thanks in advance!
Manuel
