Need A Pc5 Map For 02-05 W/99 Catless Header
10 posts Started 1 Aug 2014 Last recovered post 13 Aug 2014 Wayback Machine snapshot 18 Jan 2021
I just picked up a Power Commander V. If anyone has the following mods especially for the catless header could you please send or upload your map, I would greatly appreciate it. I only see them posted for 06-09.
2002-2005 6th gen
99 catless headers
fully gutted stock mufflers with 1.5" rear exit holes
BMC Air Filter
DEsnorkeled/flapper
removed pair Valves/Evap Canister
Stock Velocity Stacks tall rear, short front
Edited August 1, 2014 by klrtovfr
I have uploaded a map you can try from my 04 file name vfr800doin
It is a PC3 map but can load to PCV as I now use a PCV, it was dyno map.
I use Motad headers so close to same as catless 99
All my other mods are same except my mufflers are LEO
alright I will give that a try. Thank you.
I just needed something until I can make it to the dyno probably in september. Im sure the gutted stock vs leo isnt going to make a huge difference.
I hate to thread jack but a question for folks running a PCV on 02-05's - How hard was it to make that combination work?
I have an 02 with PC3 and would like to try a PCV but, supposedly, they only work with 06-09 models.
Havent got mine hooked up yet but it will work. I think you were mislead as they work on 02-09 and possibly on 5th gens as well. They usually come with a map designed for an 06-09 but you can load an 02-05 map on there. 06-09 can use the map for each gear as that is the way it is from the factory but I am unsure if it works on 02 yet.
PCV will work fine on any vtec, power commander don't list it for models under 09 because that was PCV release date. I have a PCV on my 04 (originally had PC3) you can even use the PC3 map which is compatible with the PCV. The maps however aren't backwards compatible you can't use a PCV map on a PC3. So in other words if you want to try the PC3 maps made for the 02-05 you can as they will load onto the PCV.
Isn't Tinyminds Map still in our downloads or was he using a PC3?
ya I see that his does fueling in 500 rpm increments where the others are done in 250 rpm increments.
I just installed my PCV last week on my 02 and its great, no issues for the 02-05's even though Dynojet doesn't "officially" support them. I used member GPM's fuel map as he ran a similar stock setup to myself.
Cozyes map felt exactly like stock powerwise but quite a bit smoother. Tinyminds map is ridiculous at vtec engagement, makes me lose concentration. However, coasting at 7200rpm then to wot it feels like a lot more torque compared to stock/cozyes. I get a lot of backfiring on downshifts with tinyminds also. I definitely need to get it tuned hopefully after my next track day.
End of thread · 10 posts recovered Wayback Machine snapshot 18 Jan 2021
