More Info On The Factory Accessories Ror The 8Th Gen
10 posts Started 1 Aug 2014 Last recovered post 1 Nov 2014 Wayback Machine snapshot 8 Nov 2014
If you are looking for more information on the factory accessories for the 8th gen, I stumbled on the online manuals/installation instructions today.  You can find them here:  http://cssportal.css...t.asp?group=oth  (they have a few other bikes listed as well.)
[image: Attached File]  ACCESSORY SOCKET.pdf   772.58KB   71 downloads
[image: Attached File]  CARRIER BRACKET.pdf   531.42KB   38 downloads
[image: Attached File]  CARRIER BRACKET 45L.pdf   545.88KB   21 downloads
[image: Attached File]  HANDLE ADJUST PLATE.pdf   484.67KB   59 downloads
[image: Attached File]  HUGGER.pdf   477.51KB   59 downloads
[image: Attached File]  PANNIER SET (Wave key type).pdf   733.9KB   55 downloads
[image: Attached File]  QUICK SHIFTER.pdf   1.06MB   53 downloads
[image: Attached File]  SECURITY ATTACHMENT.pdf   1.1MB   54 downloads
[image: Attached File]  TOP BOX (Wave key type).pdf   710.35KB   29 downloads
Thanks for posting this, used it to fit my hugger and the rubber backrest for my topbox. Just to buy the risers, akro can and pazzo levers (when they come out).
I'm grateful for the info too. Without this I might have wasted money on a useless power socket. GeeZ...!
I got one, it comes with the touring package. It is only live if the engine is on!! . Dont understand why they did not put a socket or 2 on the outside of the bike somewhere.
Touring package. Never heard of that. Guess that's not an option in the 'States?
Beware, the side cases are only rated to carry 13.2 lbs each.
Two gallons of milk, better put one in each!!!  $#!+....
Yes that pannier weight limit is a little disconcerting.  I suppose the dynamics acting on the panniers in bumps must have led to a conservative limit.
Handle  spacer   will  be  easy  to  reproduce   right  Seb  ...
Thanks for info very useful !
Moving the pannier locks.  Hopefully none of you have to go through this but due to a taxicab passenger not looking before swinging her door WIDE open, I ended up having to replace my panniers.  Naturally I bought just the panniers and planned on moving the key lock cylinders from the old set to the new set.
That as it turns out is do-able but not entirely without effort.
The objective is to reach what the instructions refer to as the stopper tumbler while the key is in the inner cylinder.  Depressing that tumbler into the cylinder is what allows you to remove the inner cylinder so it can be moved to the new panniers.
Often, the outer cylinder will have some hole or slot cut into the side so once you can access the outer cylinder, you can push something in to release the inner cylinder.
To reach that inner cylinder you have to completely disassemble the locking mechanism from inside the bag.  You'll need hex and Torx bits.
Then you'll discover that the outer cylinder has no hole or slot in the side.  :mad:
There's a circlip on the back of the inner cylinder which fastens it to the actuator arm for the lock and bag release mechanism.  Remove it the circlip and move the mechanism away, wipe away some of the grease in the slot underneath and you should be able to see that stopper tumbler.
I used a toothpick in the slot while rotating the key / inner cylinder to depress the tumbler.  A paperclip in the little hole at the end of the outer cylinder helps push the inner cylinder out from behind.
End of thread · 10 posts recovered Wayback Machine snapshot 8 Nov 2014
