Pazzo Lever Question
11 posts Started 17 Aug 2014 Last recovered post 21 Aug 2014 Wayback Machine snapshot 13 May 2021
My apologies in advance if this has been asked and answered a dozen times and I'm just too stupid to find it:
I just installed the Pazzo shorty clutch and brake levers on my '08. I really like them, however, I am finding the bike wont start in gear unless the lever is adjusted to position 3 or higher. Have others ran into this?? I really prefer the lever at setting one as I have short fingers and three is a bit of a reach for me. Clutch disengages correctly at all 6 adjustment levels, so I am wondering if anyone has found a way to maybe build up the contact point between the switch and the lever? Any suggestions?
Edited August 17, 2014 by NRSPTR
I have the same issue with a cheap clutch handle I installed. Thinking about epoxying a small piece of metal on it....
I hear ya, I am wondering if I shouldn't just short the switch permanently. Any issue with doing this???
After more consideration, shorting the switch would be a bad idea. You could accidentally hit the starter switch while driving.
Put a small amount of tape on the end of the switch staft or a small amount of silicone let it dry then check
Mine did the same thing. Wasn't too much of an issue as I normally started the bike in neutral. When I stalled I'd just hit the adjuster with my finger and move the lever out to a spot where it would engage the switch. When I was rolling I'd slide it back in again.
After removing the switch and reinstalling it, I see that there is some play there on the screw hole. I was able to move the switch a little closer to the lever and tightened it down, now it is working with the lever in the first click position. I have no idea if it will stay there or eventually move away, but for now it is working ;-)
My Pazzo levers don't do this. There was no change in the clutch safety switch.
I used some JB Qwik Weld to add material to the surface of the lever where it meets the switch. One option should you need it later on. ;)
Thanks all for the input! I'm considering it resolved for now.
How much closer is the pazzo clutch lever than the stock? Thanks.
End of thread · 11 posts recovered Wayback Machine snapshot 13 May 2021
