Change A Rear Tire Without Center Stand
I haven't myself, but a bump is in order.
Not a SSA, but that's how I've always done it on my Norton using a floor jack.
Scissor jack might be kind of sketchy.
What about this little jewel ?
Also suspect that centre of gravity is such that jacking under the engine will lift the front not the rear. Probably need to find a point further back - maybe the rear shock linkage?
Team Bongo President
[image: klr650_stand.JPG]
Ok if you don't have single sided swing arm
I think he has a CBR not a VFR .
My bad CB1000R.
I once saw a guy change a rear tire on his goldwing by just laying the whole bike over on its side. I guess sometimes desperate times call for desperate measures.
yes..
simply put the scissor jack under the swing arm near the rear shock, ..if your jack has a cup area. place on the shock pivot and lift the rear wheel 1 inch off the ground. AFTER its loose..
I have video of said event .
