Make A Swing Arm Stand For Free Out A Bicycle
8 posts Started 23 Sep 2014 Last recovered post 24 Feb 2015 Wayback Machine snapshot 27 Feb 2015
materials - old junky STEEL mountain bike from craigslist for free -cut off wheel/grinder -welder this stand is 100% from the bicycle. The supports are off the swing arm, the part that holds the hub pin is the steering stem, the 2 steering stem mounts are pounded into the steering stem after taking out the bearing races and that holds the hub pin securely. I have to make a handle for it but right now it works fine. After a shake test with the wheel turned to the right it didn't move so I have confidence in the stand.   the victim [image: 20140922_082309_zpsil2oi9fe.jpg] was going to use a 9/16 impact socket as hub pin but steering stem fits perfect. [image: 20140922_082323_zps6drim4jt.jpg] it begins [image: 20140922_090158_zpsfxpscxb2.jpg] used my normal stand for reference [image: 20140922_092755_zpsqtwmjxf3.jpg] swing arm used as supports [image: 20140922_092758_zps0pq4gqr6.jpg] main parts cut up [image: 20140922_092816_zpsxrsudy7u.jpg] 2 of these 4 rings are used as races for the hub pin. they are aluminum and need to be shaved down on the outside and inside just a hair but nothing drastic. [image: 20140922_101318_zpss40rq17t.jpg] going into stem [image: 20140922_101415_zpshb1bg6qm.jpg] bubble is close enough [image: 20140922_102305_zps8fstd5hh.jpg] tacked up [image: 20140922_104114_zpsefav75ok.jpg] main part is done, just have to cut off excess tabs  [image: 20140922_114619_zpsyc9hm2di.jpg] you can see races in stem for hub pin [image: 20140922_120025_zpshym7blu2.jpg] done but a little wobbly at first [image: 20140922_122853_zpsm7igscp9.jpg]   [image: 20140922_131825_zpswn3kjdbo.jpg]
  trying to figure out a good brace position [image: IMG_20140923_075944_zps77irxsxf.jpg] my attempt at fish mouthing the tubing went ok [image: 20140923_081340_zpsbmyturo9.jpg] this could work but I changed it at the last minute [image: 20140923_083251_zpsw3jpjvkm.jpg] I turned the single bar 180 degrees but its hard to tell in this picture [image: 20140923_091818_zps0vom3sxn.jpg] here she is doing her thing [image: 20140923_093027_zpshzh8sobh.jpg] and finalized product before paint and cleaning up the welds [image: 20140923_093226_zpsfe9pdlol.jpg]
Probably works as well in the dirt too!
Dam  I  see  dozens  of  these  type  bikes  at  garbage  dump  every week .
Seems labor intensive, but a good way to reuse old stuff. :beer:
2 hours working with your hands and making something useful?
I saw an aluminum stand for a ducati with a single sided swing arm for 150 dollars... I'm thinking that's not a bad deal...
I love the idea of home built stuff like this! Good for you for taking the initiative and running with it!
I took a similar approach, used some recycled 1.5" .120 wall tubing.
[image: 20150224 113643[1]]
20150224 113643[1]
Homemade VFR stand.
End of thread · 8 posts recovered Wayback Machine snapshot 27 Feb 2015
