For some reason I'm unable to post a direct link to the eBay auction, but if you do a search for auction #251664322620, you'll see the bike. The seller is an authorized Honda dealer.
I don't ever recall reading about a standard tranny failure on the 1200.
@ Ishark. That's what I'm thinking, too. And who knows how close the engine is to throwing a rod or how close the bike is to blowing the rear end (or whatever you call a bike's equivalent of a ring and pinion.)
I'm thinking I should get a '10 since I'd want to have it painted white, anyway. There are definitely deals out there on 1200's. In the last month alone I've seen a new '10 for $7,999, a new '12 for $9,999, and a new '13 for $10,999. All non-DCT's.
There is a used '12 near you on CL that you could get for $8500.
About 1/2 the time, my '13 won't shift from 2nd to 3rd (it misses) if I run hard from 1st to 2nd and keep full throttle while in second and momentarily let off throttle (fraction of a moment) as I slam the kicker into 3rd. The work-around for my problem is to fully disengage throttle while in second (literally feel the drive train backlash) for just a moment before shifting into 3rd. This problem occurs only when I run hard and keep power on while shifting and the bike is hot.
In otherwords, I can't drag race without hesitation as I slam from 1st to 2nd to 3rd.
End of thread · 10 posts recoveredWayback Machine snapshot 6 Oct 2014
