I decided to replace the bulbs with LED versions while I wait on more products to be released for the 8th Gen and/or more ideas to him me. This was a fairly simple deal, but you will need 6 Ohm load resistors to keep the blinker speed in check. I used Putco Plasma LED bulbs based on the reviews I read and the guarantee. Just pull the cover off the taillight, unscrew the two bolts that hold the rear taillight assembly in place, swap the bulbs and install the load resistors. I put mine under the wires that feed each bulb and just slit the cover of the factory wire sheath and tapped the wires with positaps.
[image: Attached File] IMG_0074.JPG 43.05KB 29 downloads
[image: Attached File] IMG_0073.JPG 38.48KB 22 downloads
As you can see, they are noticeably brighter
[image: Attached File] IMG_0076.JPG 45.74KB 20 downloads
Next up was the SW-Motech rear rack with the Givi Monokey plate for my luggage. I really like this rack and waited weeks for it to arrive. The only downside is that it has no grab handles.... which I didn't mind. It is heavy though... I feel like all the weight I lost with the Akrapovich pipe was just bolted back on :) I got mine at Twisted Throttle since SW-Motech won't ship to the US directly to customers. It is a well made rack and looks great.
[image: Attached File] IMG_0082.JPG 50.11KB 22 downloads
[image: Attached File] IMG_0086.JPG 44.2KB 21 downloads
Check out the blocking plate to keep whatever out of your underseat space
[image: Attached File] IMG_0083.JPG 35.17KB 24 downloads
[image: Attached File] IMG_0085.JPG 35.28KB 22 downloads
It has metal spacers to keep the fairing in place, nice touch!
[image: Attached File] IMG_0084.JPG 33.63KB 23 downloads
This shot shows the clearance over the taillight
[image: Attached File] IMG_0089.JPG 43.02KB 21 downloads
With a Givi T459 Attached.... and a photobomb
[image: Attached File] IMG_0095.JPG 41.35KB 23 downloads
[image: Attached File] IMG_0094.JPG 34.41KB 20 downloads
Without any luggage
[image: Attached File] IMG_0091.JPG 56.41KB 24 downloads
