Heated Grips
20 posts Started 12 Dec 2014 Last recovered post 4 Jan 2015 Wayback Machine snapshot 2 Jun 2015
Anyone had an issue with heated grips.  On the odd occasion I have started the bike up and the heated grip icon on the dash continues to flash without the grips actually coming on. I am unable to re-set the grips unless I turn the ignition off. Maybe I am doing something wrong or maybe there is an issue.  Just wondering if anyone else has noticed anything.
Thanks for any input.
nope. Been using them alot lately and no problems
Sounds  like a  loose connector .
Thanks.  I'll keep an eye on it and take it to the dealer if it does it again. Useful thing to have, heated grips at this time of year.
Mine have been fine.  Any chance you are trying to turn them on too soon or hitting the switch with your hand inadvertently while starting the bike?  The system needs a moment to initialize after a normal engine start-up.
Rob
As above, they shouldn't come on with the engine but should need to be turned on again afterward. If they're still on when you switch the engine off they remember what setting they were at and revert to that when you hit the switch.
or week battery. As per OEM heated grip manual: flashing indicates problem with the charging system and grips will not come on. Also can be water/moisture in the controller  that shorts them out (know problem if a dealer installed these grips)
Mine was doing the same. It started happening more and more until finally it came up "E3" on the dash all the time and they wouldnt work at all. Honda struggled to find the problem. They tested both grips manually with a volt meter and both seemed ok so they replaced the heated grip relay but they still didn't work. They ordered a new set of grips fitted them one at a time. Turns out it was the grip with the switch on it. They weren't sure but they think the switch was sticking inside.
Hi All.
Some Grip Heater general info and Error Codes. Hope this helps.
Cheers Grum.
  • [image: Attached File]  Grip_Heater001.jpg   52.86KB   12 downloads
I am getting 3 flashes on the button on the grip.  I emailed the dealer and they said they will hook it up to the Honda diagnostic system.  Will probably get done in the New Year.  If I understand the diagram posted above, it looks like there might be an issue with the switch.  Good find by the way. Might look at getting one of these Shorai batteries.  I always seem to have battery issues on VFR models.
Hi Provence. Sounds like you may have the same fault as Orkid 101. Three flashes on the switch and an E3 code on the instruments means it could be a sticking switch.
I'm surprised to hear you say you have issues with the VFR batteries, my four VFR's never suffered a battery failure, I did sell each bike at around 4 to 5 years of age, but the original Maintenance Free Yuasa battery is a very high quality battery, a buddy of mine had one in his Suzuki RF900 for 16 years! - BUT like any lead acid battery they like regular use OR if your bike is going to sit in the garage for months on end you need to attach a battery charger/maintainer otherwise they will sulphate up and destroy themselves.
I'm booked in for the 10 Jan.  The more information I can give the dealer the better. Sounds like a switch issue. I think my issue with batteries stems from the fact that my commute to work is only 5 miles and the revs never get higher than about 3-4000.  I do charge the battery every couple of weeks but I hear that starting a V4 engine requires a fair amount of power. Happy New Year by the way.  2014 probably won't go down as one of the better ones.
I first noticed my grips playing up when they turned themselves on on their own but I could turn them off without turning the ignition off. After a while they started to come on when I first started the bike and I couldn't turn them off by the switch I had to turn it off at the ignition. Then one day it came up E3 on the dash and they wouldn't work at all, hope it helps.
Mine has the same issue.
First happened after I had nor run the bike for four weeks, but the battery was regularly charged. First time the heated grip indicator just started flashing. Turning the bike on and off a few times cured the problem. Next time it happened it was showing the F3 code so I booked it into the dealer. A fair few VFR800's have had the whole left hand switch assembly changed under warranty due to this problem (dealer information). The dealer could not replicate the problem on my bike in the workshop so it was given back to me in the original state. The problem occurs every time the bike has not been started for some time. I don't ride much in winter, but the bike gets a regular battery charge once per week, and the odd ride when weather permits. The bike is so new that everything is a learning curve, but the malfunctioning heated grips switch is apparently a known problem.
Strangely my dealer had never heard of any other problems concerning the malfunctioning gear indicator display, in spite of every press test bike developing the problem. Mine has too, but this is another "glitch" that will have to be ironed out during the warranty period.
"Used to be", rather. Yuasa has been plagued by qc issues in the last couple of years, even with their airliner batteries.
Many NC riders had to replace them within the first few months. Mine died shortly after the 2 years warranty period. I now got a cheap €35 battery and I'm sure it will work for another 2 years just fine.
Thanks Orkid and Gonzo for the feedback.  At least I can go to the dealer with a little bit of data.  Don't know whether it is a coincidence that all our bikes are UK bikes. Do I understand from Gonzo that the dealer has not fixed the problem  Or are they going to change the grip.  This looks like the obvious solution.  And it looks like Honda must be aware of the problem.  With the new crossrunner coming out you would have thought that Honda would want to avoid any issues with this new offering.
What's the gear indicator fault??
On the grip switch I am getting 3 flashes followed by a pause.  On the dashboard I am getting continuous flashes. If I turn the ignition off, the grips seem to re-set themselves.
No problems here yet with my very-low SN USA bike.  Finding the grip heaters to be quite useful in these below freezing conditions lately!
the MCN test bike seems to have a dodgy gear indicator which displays a line and can only be cleared by switching the ignition off. I must say in 6months of ownership I have not had this happen once. I wonder if it's related to the quickshifer mod
End of thread · 20 posts recovered Wayback Machine snapshot 2 Jun 2015
