No Sparks In Ignition Coil
4 posts Started 13 Dec 2014 Last recovered post 13 Dec 2014 Wayback Machine snapshot 16 Jan 2015
Hello every one
sorry for my poor english :unsure:
I bought a vfr750f 1987 3 month ago,it was dissassmbled and the engine was off for about a year.no spark unit no ometers
then I bought the spark unit from ebay and installed the wiring.
ignition switch,clutch switch and nutral indicator works the the engine starts but it wont spark :wacko:
how can I make this engine run
I want to use in on a buggy
  • [image: IMG_20140806_104638.jpg]
  • [image: IMG_20140815_173453.jpg]
  • [image: IMG_20141023_125519.jpg]
Stand switch?
khosh amadid to VFRD!
In the download section you will find the workshop manual for your bike
http://www.vfrdiscussion.com/forum/index.php/files/file/156-vfr-86-service-workshop-manual-in-eng-deu-fra-esp/
The rc24 model does not have a stand switch. It has a neutral switch and a switch on the clutch mastercilinder. Starting is possible with the gearbox in neutral, or the clutch revoked. You need the right ingnition box. There is a difference between the 86-87 model and the 88-89 model. A ignition box from a 88-89 model will not work on the 86-87 model.
You can bypass the clutch switch, by connecting the greenred and green wire wich normally are  conncted to the clutch switch.
Succes.
And we like pics from the buggy, because a VFR engine is a very good choice, for a fast buggy.
End of thread · 4 posts recovered Wayback Machine snapshot 16 Jan 2015
