* Are items done this winter. -lbs
*F4I Front wheel, wheels powder coated -75
Two Bros Full System, *repacked, ceramic coated and TI wrapped rear downpipes removed heat-shield -12.5
Hell SS lines
Race-tech springs and gold valve kit, raised 8mm
Pazzo levers
Zero gravity DB screen
2002 mirrors
Painted grey dash panels Back
*CBR1000 Coil On Plugs -1.25
Pair valve removed -1.5
Air-box mod w/ *Pipercross
*Samco hoses
*Barnett clutch springs, rebuilt slave
*Valve clearances adjusted
Pro Factory Star Shifter
CBR1000 Alloy Kickstand and kill-switch -1.0
Removed center stand rear sets ect. -7.0
CBR600 pegs .25
Haris CF huger & moded
520 sprockets -1 front, and chain -2.5
Shori battery -7.5
Penske rear shock, raised -2.5
PC3, with custom map
*Galfer rear roter -2.0
*Cush drive bushings replaced
*TI bits -2.0
Thanks to Mohawk, and others on forum for your help and inspiration. Now just waiting for spring!!
That's a nice list. Which CBR kickstand works? Pics?
[image: msg-23210-0-31999600-1409484809.jpg]
2014 cbr1000st, stand, spring, nut, and bolt needed, and made an alloy spacer. Need the kill switch as it operates it reverse, plugs straight in. Unless you want to bypass, which gave me anxiety at every use without. Stand is 1/2 longer, good if rear has been raised. All parts = $135 new
I picked up a stand and went to do this mod tonight. I ran into a problem with the size of the hole in the original 2001 stand base. Looks like it needs to be bored out to 18 mm.
Can you tell me if you did that to yours?
yes sorry, I removed the mounting bracket put it in a clamp and drilled, you may be able to do on the bike if someone is holding the bike. Also you can see in my pic i cut the foot tab down, one cut at an angle from the top then used a bit black touchup paint, it is very long and the angle will interfere with upshift. I used washers as a spacer and they would bind, so cut alloy spacer, when lubing chain will hit spacer with chain lube or wd40 moves freely.
Can't wait to see you on the Dragon .
Good Work !!!
Love all the mods but for Christ's sake lose the bra.... it's so 80's! :tongue:
Good work, I copied the stand install in my own fashion, thanks for the tip :)
i love the bra, and it goes so well with my Members Only jacket and high top Reeboks i wear when i ride.
Good Work !!!
Thx,
Just waiting on Dmr cartridge kits which should be hear next week, and Samco thermostat hoses (which are not included in the kit)?? Then i can get my throttle bodies back on, put her back together, and i should be ready to head that way for the day!
I lost 15 lbs off myself. So much cheaper. Then I went and bought adjustable rearsets for the VFR that were way too expensive. Put more work into the BMW to make it a touring bike, which could have bought a well loved 5th gen. So much for limiting expenses. Happiness on a motorcycle that is just right: Priceless.
Can't wait to see the 07 RWB, looks like spring is finally here.
