Looking to do some maintenance - valve check, oil, K&N, maybe send off my ECU, possibly exhaust, and final drive oil.
Do i need to get a pitbull, or is the kickstand sufficient?
if you do any touring, suggest getting the Honda center stand. Now you will have your stand with you wherever you go.
I went with the center stand, but my understanding is that if you add a front stand while the bike is on the OEM center stand, the back wheel will hit the ground (e.g., you need a board under the center stand to keep the rear high enough off the ground when using a front stand, or take the rear wheel off first...)
OEM stand can be found for less than $200 shipped.
-Dan
I had the Honda center stand on for about 2 seconds before replacing with my own home brew paddock stand. The centerstand just wasn't wide enough to be stable when using a front stand.
