Has Anyone Fitted Led Turn-Signal Bulbs?
11 posts Started 8 Feb 2015 Last recovered post 14 Feb 2015 Wayback Machine snapshot 1 Jun 2015
Has anyone replaced, or looked at replacing their stock indicator (turn-signal) bulbs with LED equiivalents? It bewilders me that Honda designed the 2014 model with LEDs for the head-lights, brake-lights, and tail-lights, but settled for conventional filament bulbs for the turn signals.
Keen to hear from the assembled sagely wisdoms... ;-)
On my 5th Gen, yes. Also replaced the taillight (main reason for doing the indicators as well). There's no significant advantage (maybe bulb lifetime), but I broke my taillight and it was an opportunity to bling the bike a little.
I remember busting my ducktail on my 5th gen, and fitting SilverStar globes as part of the replace/repair, but those are still filament bulbs. I was wondering if someone had happened across plug-n-play LED replacements, rather than needing to fit some 6-ohm load resistors as well.
Has anyone opened up their 8th-Gen mirrors (where the indicator bulbs live)?
Ok, just did that - not terribly difficult actually, just one screw and some tabs (consult your owners manual for the correct order).
Although soldering doesn't bother me, if I can find a plug'n'play option, then so much the better. Having determined the fitted filament globes are BAU15S-type, I'm looking at something like these: http://www.ebay.com/...b-/221683611919
Does anyone know if the RC79 (8th Gen) has a CANBUS wiring loom?
Don't bother with resistors; just go on ebay or whatever; the indicator unit that works for LED bulbs (and also filament bulbs) is very cheap, and just plugs in, in place of the other one.
The double rear incandescent bulbs for my 95 VFR tail/brakelights were big power eaters, judging to how really hot they get. I manage to burn my fingers bad removing them from the bike after having them on for only a very short time. I actually saw a nice voltage jump on my voltmeter after I replaced them with LEDs the slight reduction in voltage when braking also disappeared with the LEDs. So pretty much, my LED bulbs are close to transparent to the electrical system. I'd like to change over to LED bulbs for the signals and front running lights too, but I think I will need some sort of resistor in the system to make them blink for the signals?? I'm just too lazy these days to deal with it, so the front and rear signals and front running lights still have incandescent bulbs, but definitely in my long range to-do list with the bike.
I've been advised that the Gen-8 has a standard rather than CANBUS wiring loom, which means the flash relay will be expecting to see ~21W (x2, front and rear) worth of current drop during operation. The less current seen, the faster it will flash, and since LEDs are low current devices, without adding a resistor, straight LEDs will blink really fast - worth a defect notice in most places. You could swap the flash relay too I guess, but I'm looking for the simplest option, perhaps an LED festoon that already has the restistor built in.
Worst case scenario, I'll fit another round of Philips Silvervision PY21W's like I did with my Mazda;- whilst still filament globes, they have a nice silver finish when not illuminated, which means your light housings stay clear/white, rather than reflecting the unliminted amber bulb.
I like the fact that the "normal" bulbs are big power eaters; it means the RR doesnot need to convert it in heat...
As for light output, I hope that the latest LED light output has improved over 1st model LEDs
A neighbor gave me 2 of these:
[image: Attached File]  post-5787-0-37340500-1380995243.jpg   35.5KB   5 downloads
So I fitted one to see the difference...
NO prizes for guessing which is which..
Taillight only
[image: Attached File]  post-5787-0-41015300-1380964708.jpg   22.53KB   6 downloads
Taillight+brakelight
[image: Attached File]  post-5787-0-38373500-1380964729.jpg   23.85KB   6 downloads
I gave the bulbs back....
I just tried led bulbs in rear running and brake lights on my 02vtec...took them straight back out.. They were shit...
Thanks Dutchy & M14dgt for the comments. I've seen some crappy LEDs too, but they tend to be first-generation diodes. Most of what's around these days uses improved Surface-Mount Diode (SMD - the little white square-looking ones) or Cree diodes. I tend to stay away from the dome-style old-school LEDs - they've had their day and been superseded by better things. The modern ones I have installed on my Mazda look every bit the business.
I have cree based tactical lights the size of my thumb that put out a thousand lumens. The technology exists... For a price.
End of thread · 11 posts recovered Wayback Machine snapshot 1 Jun 2015
