Has Anyone Tried The Spray On Window Tint On Their Windscreen?
8 posts Started 27 Feb 2015 Last recovered post 22 Mar 2015 Wayback Machine snapshot 21 Jun 2015
The windscreen seems like a reasonable idea but I've never understood tinting your head/tail lights. I would like my lights as bright as possible.
I tried to tint mine (with film, not spray) and I finally decided to just paint it flat black in honor of TTC... Looks great IMO! Besides, I never tuck all the way down behind it on my Y2k... I keep my eyes just above the top of the wind screen when I tuck in tight.
I think I'll give the tint spray a try and if it looks like crap then use paint. I'll post an update when I do it. Thanks
Try using Plasti-dip if you're planning on using paint instead, it will peel right off if you find you don't like it. Saves you from ruining a good face shield.I think I'll give the tint spray a try and if it looks like crap then use paint. I'll post an update when I do it. Thanks
I sprayed the back of my stock one gloss black. Looking at it from the front it looks great. If you do go the paint route, paint the back side.
[/quote]
Mine is on the home page right now with the flat black painted on the inside of the wind shield if you want to see what it looks like. The plastic gives it a smooth glossy look when viewed from the outside and the flat black cuts reflection and light on the inside[/quote]
I did the same on my 2003. Used Krylon black for plastics. Looks great, hides my radar detector and keeps the hot sun and glare off the gauges.
End of thread · 8 posts recovered Wayback Machine snapshot 21 Jun 2015
