Tank Breather
7 posts Started 2 Mar 2015 Last recovered post 3 Mar 2015 Wayback Machine snapshot 1 Jun 2015
I'm a new owner of a 2014 VFR800F.
I've noticed that a vacuum seems to form in the tank - sometimes really hard to open the filler cap due to the suction.
I assume there must be some kind of tank breather, but can anyone tell me if it is in the filler cap or somewhere else. I see there are what appear to be three breather pipes just behind the left footpeg and wondered if there might be a kink in the pipe. I don't want to start pulling of plastics if the problem is with the filler cap.
I had a similar problem years ago, but that was with a carb'd bike, and gravity feed. Once the pressure got low enough the bike just stopped - it turned out that the end of the breather was blocked with road dirt.
Sounds to me like a vacuum hose got squished under the tank. Has the tank been lifted recently for some reason?
Possibly - Scottoiler fitted by dealer a few weeks ago.
Thanks for that - I'll check it out.
Hi mikmcd and welcome.
Hope you get that sorted soon. You could always take it back to the dealer that appeared to cause the problem.
Thanks - I probably will, but I always like to get to the root of a problem myself first. I have a pretty stubborn nature and hate to be beaten.
I haven't used the bike much thanks to our foul weather - haven't even had first service yet. Hoping to do a bit of touring in the spring, so want to get any niggles sorted out before then.
Hi and welcome. I had the 'kinked tube stops the engine when the vacuum builds up' problem on my old CBR600 a number of years back but haven't had any trouble opening the cap on the new VFR.
End of thread · 7 posts recovered Wayback Machine snapshot 1 Jun 2015
