Upper Radiator Guard
7 posts Started 22 Jun 2015 Last recovered post 26 Jun 2015 Wayback Machine snapshot 26 Jan 2016
After a tale of woe from one of the guys on the UK VFR forum when a stone in his radiator caused his bike to overheat - http://www.bikersora....d.php?t=128775 - it's obvious the top rad is in direct line with the gap between the forks with no protection from flying debris and needs some sort of guard. R&G (famous over here for their crash protectors) make guards for a range of bikes and have just started making them for the new VFR so I bought one. Clear instructions included and also available on their website (except I'd suggest also removing one more piece of the inner black fairing each side to improve access) and easy to fit. It attaches using the radiator mounting bolts on the left side and two cable ties ('zip ties' to you!) on the right. Very neat.
By the way, has anyone else noticed what a grit trap the bottom of the fairing is? Any ideas for dealing with that? When I wash it I remove the plastic clip each side there to let the water drain out but it doesn't clear the gravel!
  • [image: Attached File]  2015-06-21 2 top rad guard fitted 3.JPG   51.6KB   9 downloads
  • [image: Attached File]  2015-06-21 3 fairing off left side 2.JPG   122.16KB   9 downloads
  • [image: Attached File]  2015-06-21 4 grit trap.JPG   46.05KB   9 downloads
  • [image: Attached File]  2015-06-21 1 top rad guard fitted 1.JPG   46.61KB   9 downloads
I just blast the hose in there from the vent in the side to wash it all out
Nice that was going to be a winter project of mine, or one when I got around to ordering one  :smile2:  . Good pics.
R&G are now making a stainless version as well, if that's more your thing, costs a bit more though.
That bloke must have been unlucky to cop a rock up there, but shit happens, especially in group rides if you are close to the bloke in front of you and especially if he has a sticky rear.
Doesn't take a sticky tyre to fling a stone. Cold have been flung out from between threads.
What I will add to fat shoutys post would be if you have the fairing off make sure you coppaslip that bottom bolt or change it for stainless esp in the UK as it will rust.
+1 to that, I replaced over 200 nuts, bolts and other things on my 5th gen with stainless or titanium which is why it still looked this good at 9 years old. I'm doing the same to the new one.
  • [image: Attached File]  VTEC.JPG   64.26KB   4 downloads
End of thread · 7 posts recovered Wayback Machine snapshot 26 Jan 2016
