Does anyone know where the service connector is located on the 2014 onward VFR800F? Is it still a 2 pin connector and do the codes correspond to previous generations? Thanks
Service Connector
6 posts Started 5 Jul 2015 Last recovered post 9 Jul 2015 Wayback Machine snapshot 25 Jan 2016
Remove the seat and the battery cover. The service connector is located right next to the +pole of the battery. It is a four pin connector with a "dummy plug" on it. Remove the dummy plug and short two pins to access the error codes (connect a jumper between the brown and green wire).
Thank you :)
Problems ?
No problems, I'm going to Europe on the bike and like to be prepared!
Ah have fun ..
End of thread · 6 posts recovered Wayback Machine snapshot 25 Jan 2016
