Alternative To The Plastic Clips?
10 posts Started 11 Oct 2015 Last recovered post 13 Oct 2015 Wayback Machine snapshot 18 Dec 2015
So. I finally broke one of the stupid plastic clips the holds the lower fairing together on the underside.
Why did Honda build a sturdy work horse and decide to put these utterly silly plastic clips underneath? Since they fill with sand and dirt they get stuck ... so they break when you try to take them out. :mad:
Anyone that have come up with an alternative, easy-to-use solution/alternative?
[image: Attached File]  IMG_20151011_145801.JPG   50.1KB   18 downloads
same seller.
I use a zip tie across the two left/right holes; it securely holds all four panels together.
I just clip the zip tie for every oil change and replace it with a new one.
  • [image: Attached File]  ziptie.jpg   63.52KB   17 downloads
I do the same thing on my 5th gen. Easy.
I never noticed the 8th gen had those. For some reason I was assuming it had the same or similar system as the 8th gen with zero fairing bolts and clips.
On my 5th gen, I just bought a huge bag of them like the guys above mentioned. I believe that Veefer was the one that clued me in on the zipties under the bike too. So much better that way!
Thanks SlideRule!
That's an easy solution. I'll try that when I re-mount the panels.
I already have a 250-pack of plastic studs in the garage, but I simply don't like to fiddle with them.
How does that work? The 5th & 6th Gens are different to the 8th Gen; there are only 2 holes and they are separated by several inches fore/aft. Do you just loop a single zip tie through them both?
End of thread · 10 posts recovered Wayback Machine snapshot 18 Dec 2015
