3Rd Gen Voltage Output
7 posts Started 13 Dec 2015 Last recovered post 18 Dec 2015 Wayback Machine snapshot 13 Mar 2016
Hi folks,
Can I get someone to check the running voltage at the battery of their 3rd gen with the mosfet R/R - idle up to 3000 or 4000 RPM, please? I just put my replacement mosfet R/R in and am getting 13.80-13.85 volts at any and all RPM's.
On the face of it that should be fine as the normal voltage of the AGM battery is 12.8 anyway. However, if I were to put in a LiFePo4 battery that won't be enough. They require 14.2 charging voltage. I do get that and a bit more with the original R/R. I keep asking myself why I changed it to get less output. Mind you, it is exceptionally stable voltage at all RPM's where the original R/R allows more variance depending on revs.
Thanks,
Glenn
I don't have a MOSFET reg/rec on my FP, but the spec is 13.5v - 16v @ 5,000 rpm, so your reg/rec seems like its working.
Thanks JZH. I think it will be OK, then. Hopefully others can jump in with their numbers for real peace of mind.
Cheers,
Glenn
My RR voltage is anywhere from 13.5-13.8 on my 92 VFR.  A little on the low side.  I have an OEM RR with heavier gauge stator wiring and a ground directly to the battery. Was thinking about upgrading to a Mosfet RR.
Roger
Thanks vfracer750. Yeah, same as mine is now with the mosfet R/R, but mine is oddly 14.4 with the original R/R. Still, I think it will be perfectly fine (yours, too) since it is still a full volt above the resting voltage of a good AGM battery. I just don't think it is enough for the LiFePo4 batteries if I chose to go with one of those next time. They need 14.2 volts.
Cheers,
Glenn
16 volts might be TOO MUCH.  :comp13:
It might be, but it is the Honda spec...
End of thread · 7 posts recovered Wayback Machine snapshot 13 Mar 2016
